Previous in Forum: What is the Difference Between Sensitive Earth Fault & Rotor Earth Fault   Next in Forum: Ability to plug into multiple power sources
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Solar Tracking System
02/01/2012 1:19 PM
hi am doing project on solar tracking system based on stepper motor,microcontroller. I need stepper motor torque equation.I need information abt which stepper motor should be used to rotate the 2.2kg solar panel. reply me soon pls!
All is well !!! All is well !!
Re: Solar Tracking System
02/01/2012 3:07 PM
Anonymous Poster #2
02/01/2012 10:15 PM
Thank u sir....
Anonymous Poster #2
02/01/2012 10:20 PM
sir it may be a silly question but i need help to do my project on solar tracking system. I need exact rated stepper motor to rotate my 2kg solar panel? can u help me!
02/01/2012 3:20 PM
Translated...
"Hello,
I'm being paid to design something that I am unqualified to do, but I beat out qualified experienced engineers in other countries by being cheaper than them to do it. Now I have to perform on my contract, so I need you pathetic losers to show me for free how to accomplish this."
Good Answers: 181
02/01/2012 7:07 PM
Why did you mark yourself off topic? I think you've hit the nail squarely on the head.
03/22/2012 1:16 PM
Decades ago, in graduate school, I was assigned to devise a way to stabilize the image of the sun on a sun-pumped laser. The "given" was an expensive telescope mirror system with one of the mirrors steered by electronics. There were high and low frequency components to the satellite motion. I got a A+ for throwing away the beryllium telescope and using a large plastic fresnel lens steered by small fluid cells on the support struts. When the image of the sun got off center, it would heat one of the cells which would then exert pressure to move the lens. That took care of the low frequency motion. The high frequency jitter was taken care of by making the image of the sun much larger than the end of the laser rod, so the rod remained illuminated even as the satellite vibrated. Yes, most of the captured sunlight was wasted, reflected back into space, but, WTF, sunlight is really cheap in space. Do you really need a stepper motor, etc. to get 15 deg./hr?
Register to Reply 6 comments
Anonymous Poster (3); esbuck (1); TonyS (1); wareagle (1)
