Previous in Forum: How to Find Aluminium Die Casting Companies in India?   Next in Forum: Crazy Dash Lights
9 comments
Quad Bike Stuck in First Gear
02/02/2012 2:42 PM
My Honda quad bike is stuck in first gear and I cannot start it up.
Pathfinder Tags: QUAD BIKES
Good Answers: 58
Re: Mr DONALASDAIR SMITH
02/02/2012 2:48 PM
Have you tried applying the clutch
02/02/2012 4:01 PM
QUAD IS A HONDA 329cc PETROL ENGINE , IF IT HAS A CLUTCH I HAVE NOT SEEN IT BUT MAYBE AT 73 YEARS THERE IS STILL A LOT THAT I HAVE TO LEARN. THANKS ANYWAY.
Good Answers: 44
02/02/2012 4:22 PM
WHAT??? I CNAT HERE YOUR!!!
MAYBE YOU SHOULD TAKE OFF TH ECLUTCH COVER! THAN YOU COULD SEEN IT!
YORY HONDA IS 73 YEARS OLD?
02/02/2012 4:16 PM
These machines have automatic clutches....
http://www.atvsource.com/manufacturers/honda/2001/rancher.htm
Re: Quad Bike Stuck in First Gear
02/02/2012 3:44 PM
Here's a shot in the dark, since we have no way of knowing the year and model...
"The problem is the tilt sensor on the motor. replace it and take it to a mechanic or your dealer to get the ecu reprogrammed and you will be in business. i changed the sensor myself with the bike on my trailer. and then carried it to my buddys to reprogram the ecu. jst make sure the ecu has been reprogrammed before you start the bike or you will have the same problem with the new one. "
Read more: http://forums.atvrideronline.com/70/7166159/honda-atv/05-rubicon-stuck-in-1st-gear/index.html#ixzz1lG8jeOyV
02/02/2012 4:03 PM
THANKS FOR THE TIP. WHERE I STAY I THINK THAT I WILL HAVE TO GET SOMEONE TO HAVE A LOOK AT IT.
Good Answers: 123
02/08/2012 12:46 PM
I once had an 86 Walters with an Allison HT750DRD transmission that had a bad engine mount. Every time the engine would shift, the cover for the transmission governor would hit one of the water pumps. Eventually it would dent the cover sufficiently to damage the spinning weights of the governor. Then it would be stuck in either first, or second. But at least mine would start. It may be a long shot, but WTH.
Bob
02/08/2012 4:35 PM
Thanks for your reply. In the meantime I was given some info from a man who deals with quads and he said that there is a 'button'under the gearbox and that there is a tool available for turning this. I managed to obtain one and with the help of a friend we managed to turn it through all the gears until we got to neutral. I then just pressed the start button and 'magic there was a satisfying roar Thanks to everybody for the help offered.
Good Answers: 123
02/09/2012 10:03 AM
Glad it worked out for you.
Bob
Register to Reply 9 comments
bob c (2); cuba_pete (1); DONALASDAIR SMITH (3); KJK/USA (1); SolarEagle (2)
