Previous in Forum: Water Line Pipe Corrosion   Next in Forum: Mill Tolerance
Weld Quality Factor (E)
02/04/2012 11:33 AM
Hi All,
Would any of you be kind enough to confirm me following.
If material of the pipe is A358 TP 321 Class 2 EFW
A358 Specifications Quote
"1.3.2 Class 2-Pipe shall be double welded by processes
employing filler metal in all passes. No radiography is required."
Then
For Piping Stress Analysis (B31.3)
Long. Weld Quality Factor (E) = ?
I am taking 0.7.
Is that right?
Regards,
Tabby
Re: Weld Quality Factor (E)
02/04/2012 11:53 PM
I guess Weld Joint Factor E, depends on type of Examination, i.e. Spot Radiographed, Full Radiographed, etc.
as per Table No. 302.3.4 in ASME B 31.3
02/06/2012 3:58 AM
By referring to B31.1 Appendix A Table A-1B, I suppose you can take EJ = 0.85
02/07/2012 1:15 AM
Thanx guys i found it. Taking E=0.85
02/07/2012 1:55 AM
no problem! but i had written the wrong code number, it should be B31.3, fortunately, you could find it!
jaycee
Register to Reply 4 comments
Jaycee (2); sayedfarhanali (1); tabbymulla (1)
