Previous in Forum: Etching   Next in Forum: SAG Chart
Using TL494
02/05/2012 4:47 AM
Hi,
I'm new to the TL494 and i'm using it for a buck converter. So, basically i'm using it for the IGBT. I've tried carrying out the circuit given in the datasheets (for tl494) at http://www.datasheetcatalog.org/datasheet/texasinstruments/tl494.pdf
can anyone share how the test inputs (pin 3 and 4) work?
and is there a difference in the range of duty cycle if the resistors are connected to E1 and E2 instead of C1 and C2? what does this mean?
Re: using TL494
02/05/2012 5:03 AM
The usual problem with this sort of thing is trying to test it without a load connected.
Try searching for appliction notes for the device. I think Texas is usually pretty good with app notes. Or google TL494 circuits.
Do you have an oscilloscope? If no, then it's pretty fruitless trying to do any real electronics.
If Yes, are you getting the sawtooth waveform?
Re: using TL494
02/05/2012 5:56 AM
Hi Del,
I got the sawtooth waveform at first. but after trying to change the components positions, by having C1 (pin 8) and C2 (pin 11) connected to Vcc and resistors at E1 (pin 9) and E2 (pin 10), i didn't get the result i wanted. so, i connected them back according to the circuit shown. unfortunately i didn't get the output. the resistors did get really hot when i tried. is it possible that the tl494 is damaged?
Re: using TL494
02/05/2012 7:39 AM
Almost certainly. If you return the circuit to a previously known working state and it no longer works, it's a pretty good bet it's blown.
Good Answers: 38
Re: using TL494
02/06/2012 12:51 AM
putting VCC on the outputs? C1 and c2 why did you that?
you could play with RT and CT values
And the 1in+, 1in- and 2in+, 2in- voltages
but never exceed the absolute maximum ratings on any in- or output
Re: using TL494
02/06/2012 12:43 PM
Hi Epke,
i decided to try the emitter follower configuration. then getting the output at E1 or E2. it was on the datasheet so i thought of giving it a go.
may i ask, is the duty cycle controlled by feedback and dead time ctrl pins while the frequency is controlled by CT and RT pins?
Thanks!
Good Answers: 38
Re: using TL494
02/06/2012 9:26 PM
according the spec yes, the RT & CT sets the oscilator
check the apllication notes for more in depth info (like dell said)
for example;
http://www.ti.com/lit/an/slva001e/slva001e.pdf
Re: Using TL494
02/12/2012 11:40 PM
i managed to get the TL494 working. thanks for all of your help :D
Anonymous Poster (1); Epke (2); fifahaywire (2); user-deleted-1105 (2)
