Previous in Forum: Using a 3-Phase Synchronous Motor as a Generator   Next in Forum: UL Testing for Transformers and Power Supplies
Low Voltage LCD
05/03/2007 9:39 PM
Hello
Is there a Low voltage LCD panel that takes 5v or less? The normal LCD panel requires 15v - 30v.
Thank you
Re: Low Voltage LCD
05/04/2007 3:19 PM
Look for modules made by Varitronix/powertip see www.farnell.co.uk
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Re: Low Voltage LCD
05/04/2007 11:43 PM
You don't say what is to be displayed. There have been solar and battery powered calculators with monochrome LCDs operating on 3 volts for many years.
Re: Low Voltage LCD
05/05/2007 7:19 AM
LCDs don't require high voltage to function. If at all it is the back lighting that will require it.
In most cases - I am assuming TV & PC Monitor applications - the back lighting has been provided by fluorescent lamps. Now with availability of very high efficiency low cost white LEDs a number of manufacturers will gravitate to to these types to reduce power consumption & heat built up.
On most calculators with lcds AND back lighting work on 3 volts or less. Even your mobile (wireless, cellular) phones with colour lcd displays & back lighting work on 3 volts.
Your cordless handsets work on 3.6 volts.
BrainWave (1); dkwarner (1); pmshah (1)
