Previous in Forum: Porosity in Steel Sand Castings   Next in Forum: Need Basic Training in Blueprint Reading & Materials
Rubber Prosessing Plant
02/10/2012 6:03 AM
What role does a draughtsman play in a rubber processing plant??? What knowledge is a draughtsperson required to have in order to produce effective drawings in a rubber processing plant???
never let the fear of striking out keep you from playing the game...
Good Answers: 58
Re: Rubber Prosessing Plant
02/10/2012 11:41 AM
Based on the sophomoric questions this appears to be homework which is not welcome on CR4 however, I have a little time before my next meeting so I will offer my time and attempt to enlighten you on the art of how to research on your own.
First, lets find out the hows and whys of a "draughtsman". Look at the first four links (as well as more further down the page), these will provide information on what a draughtsman does and what it takes to become one.
Now, lets see what a "rubber processing plant" does. Links three through seven (as well as more further down the page) will provide information and pictures illustrating rubber and rubber processing plants.
Lastly, lets look at effective drawings or " "effective industrial draughtsmanship". On this page you will find links to training, materials, equipment, individual resumes, job offers, and job solicitations which should give you an idea of what it will take to produce effective drawings.
Through the three examples above, you should have a good knowledge of how Google works. You can enter variants of the word combinations I used in the search pane to search and get additional results.
Good Luck!
02/10/2012 4:33 PM
A, "draughtsman" produces draughts, or drawings that allow others to visualize how things fit toget her and how much of what is needed to build the plant.
First order of business is to take draughting classes, then get ME drgree.
Hurry and get started, you got a long way to go.
Register to Reply 2 comments
