My 6th Edition of "Perry's Chemical Engineers' Handbook" has a 3-page section on "sublimation" which might at least get you started. That section also includes a few references (books and journal articles).
This Wikipedia online article may also be helpful:
Does any other gas than CO2 form a solid? I can't readily think right now of any that do.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Many solids sublime. Two common examples: naphthalene ("moth
balls") and menthol. These are organic compounds, but sublimation
also occurs for many inorganic compounds. Any solid that has a
noticeable odor must sublime to some degree.
Problems worthy of attack prove their worth by hitting back. -- Piet Hein
The examples quoted do not inclued true gaseous substances. Is the an actual gas that will form a solid other than CO2. Sublimation is not really the same thing. Does O2 or Nitrogen or hellium form a solid. They can all form liquids but I have never seen or heard of them being in a solid phase.
Where did you find the distinction between "true" or "actual" gases and "untrue" or unactual" gases? Any substance in the vapor phase is a gas ... be it substances that sublime like carbon dioxide, caffeine, naphthalene, meta-phosphoric acid, formamide, arsenious oxide, chromic chloride, cobaltic chloride, nickel chloride ... or be it gases that do not sublime like steam (water vapor), propane, butane, mercaptans, nitrogen oxides, hydrogen sulfide, ammonia, and thousands of other gases.
Yes, they *do* form gases. If individual molecules floating
through the air do not qualify as gases, then what would you call them?
(the other three possibilities -- solid, liquid, or plasma -- don't
apply)
in a solid phase.
O2 and N2 do form solids, at 54.36 K (-218.79 °C, -361.82 °F) and
63.15 K (-210.00 °C, -346.00 °F), respectively. Helium does not
form a solid at ordinary pressure (1 atm), even at a temperature of
absolute zero (0 K, -273.15°C, –459.67°F). Solidification of helium
requires a combiniation of extremely low temperature and extremely high
pressure.
Wikipedia serves as a great source of information -- you should try it.
Iodine, but on a different temperature scale. Solid on ambiance, straight to gas with very little heat. It will sometimes sublimate in ambient temperature, given low pressure
