Previous in Forum: Motor Ampere of Cooling Tower   Next in Forum: Pump for Vertical Beach Well
Low Vacuum in Condensor
02/16/2012 5:50 PM
dear
what is the effect when turbine running with low vaccum & why steam flow increase with low main steam pressure or high back pressure in condenser
Re: Low Vacuum in Condensor
02/17/2012 3:31 AM
If you've got low vacuum in the condenser, Uncle, then you will have a low pressure drop across the turbine. So to get the same amount of power from it, your steam flowrate must increase; it's as simple as that.
Good moaning!
02/20/2012 2:00 AM
For further confusion, your condensor load will increase, turbine efficiency will decrease and a stage will come your turbine will trip.
Good Answers: 102
02/20/2012 5:53 AM
Welcome to CR4 Mohammad.
Not too long ago there was another CR4 thread about a problem with a condenser and its vacuum.
There was lots of good stuff to learn proffered by many there. It was discussed in some detail.
Perform a search of CR4 to see if you can find that particular thread and have a read.
Register to Reply 3 comments
Crabtree (1); Mukesh0861 (1); Wal (1)
