Previous in Forum: How to See the Following of Data from PC to Servo Drive   Next in Forum: Transformer - Maximum Efficiency
Two Semi-Conductor Shield in HT Cables Why?
02/19/2012 4:34 AM
i seen the 6.6kv termination in that around the Alluminium conductors there is black semi-conductor layer and after tat ve have XLPE insulation and over XLPE insulation another black semi-conductor layer....
i cant understant why there is 2 semi- conductor layer in a HT cable...???
pls some one explain.....
Good Answers: 170
Re: Two Semi-Conductor Shield in HT Cables Why?
02/19/2012 8:05 AM
The first one is called "conductor screening" and the second one is called "insulation screening".
02/27/2012 10:29 AM
Tnks sir for ur reply but i seen the semi-conductor layer( insulation screen ) is peeled to some distance and we are doing meggering why...????
what is the differenc ebetween insulation screen and conductor screen...???
then where is semi-conductor layer...????
Good Answers: 181
02/19/2012 3:25 PM
With unscreened cable there are stress points between the conductors. The screening equalises the stress around the core. The outer screening evens out the stress to earth.
Jointing or terminating the cable requires stress relief at the end of the screening so that there isn't a sudden stop which will cause insulation failure.
Hope this helps.
Register to Reply 3 comments
electricalexpert65 (1); mohsinhamid (1); TonyS (1)
