Previous in Forum: How to Calculate the Press Speed (SPM) for High Speed Progressive Die   Next in Forum: Lower Temperature Material and Lubricant?
Difference Between ERW Pipes and UOE Pipes
02/19/2012 6:27 AM
Hi, I am currently face an enquiry which required ERW pipes and UOE Pipes. I found out most of the factories can offer ERW and JCOE BUT NOT UOE.
Can someone helps to clarifies what the difference are for ERW, UOE and JCOE??
Thanks
orp
Good Answers: 104
Re: Difference Between ERW Pipes and UOE Pipes
02/19/2012 1:04 PM
OP,
What do the acronyms ERW, UOE, and JCOE stand for?
02/19/2012 8:11 PM
Bigg,
ERW adopts to manufacture the pipes by the Electric Resistance Weld process.
JCOE adopts continuous axis contorting J-C-O (J-ing, C-ing and O-ing)process with characteristics of high forming accuracy and efficiency as well as balanced distribution of forming stress.
UOE adopts (U-ing and O-ing)process with characteristics of high forming accuracy and efficiency as well as balanced distribution of forming stress.
I hope this helps.
Orp
Good Answers: 34
03/06/2012 4:06 AM
ERW is a welding processes
UOE and JCOE are pipe fabrication Methods
"The UOE is so called because it first uses a "U" press, then an "O" press to complete cylinder forming from long plates ordered to size and grade. The cylinder is then welded inside and outside by the submerged arc process by using as many as five welding wires. For JCOE, it is named as it is pressed in to "J", "C" then "O" Shapes and expanded"
I see no way to compare them. WP.
Register to Reply 3 comments
bigg (1); orp (1); Whitephone (1)
