Previous in Forum: Cathodic Protection for UG Piping   Next in Forum: Almond Halving (Transversally) Machine
Portable Water Flow Measuring
02/20/2012 6:36 AM
Hi- Team,
Do we have any portable instrument (not fixed in line)/method for measuring water flow in pipelines?
Re: Portable water flow measuring
02/20/2012 6:50 AM
Well, when I was young, I used a thing called an ultrasonic flowmeter; these things just clamp onto the outside of the pipe and use the Doppler Effect on the stuff inside it.
Things may have moved on since then.
Good moaning!
02/20/2012 10:01 AM
Nope, they're still in use.
Good Answers: 176
Re: Portable Water Flow Measuring
02/21/2012 7:15 PM
Transit time clamp-on ultrasonic flow meters are used for clean water (fluid) and have a high degree of accuracy, if the pipe is not rusted/corroded.
Doppler clamp-on ultrasonic flow metering is used for waste water carrying suspended solids or highly aerated with bubbles. My experience is that Doppler is a relative reading ( more or less than a previous flow rate), but not useable for absolute flow rates unless there's some other means of 'calibrating' the flow, which if there was, doppler clamp-on would not be under consideration.
Register to Reply 3 comments
Crabtree (1); Iris (1); lyn (1)
