Previous in Forum: PHE Inspection   Next in Forum: Profile Shift of Helical Gear
8 comments
Reinforcing Pad Calculation
02/21/2012 4:49 AM
Good morning,
i m calculating reinforcing pad (added reinforcing area A4 as per ASME B31.3 appendix H example 2) but i have not find any formula for it.(in ring and in fillet welds) also in this example tc/0.707=0.250/0.707=0.354 define "tc"
In 304.3.2 they are refering 304.3.2(f) after that refering to 328.5.4 which also refers to 300.2 and i have not find any formula for it.
Re: Reinforcing pad calculation
02/21/2012 5:47 AM
0.707 looks suspiciously like (√2)/2, Guv (then I am a polooceman and being suspicious comes with the territory).
Good moaning!
Good Answers: 114
Re: Reinforcing Pad Calculation
02/21/2012 8:43 AM
I don't know the standards you are using, not my discipline.
0.707 is (√2)/2. that is the size of the root of the weld, the narrowest part. Normally, a fillet weld nominal size is multiplied by .707 to find the size of the root.
Good Answers: 179
02/22/2012 8:01 AM
GA for passington for nailing down the "Root" size of a fillet weld....
02/22/2012 5:32 AM
All the required details are there in ASME B 31.3 para 304.3.3. You need to go through and understand. All relevent details are there for your help.
304.3.3 Reinforcement of Welded Branch Connections.
Added reinforcement is required to meet the
criteria in paras. 304.3.3(b) and (c) when it is not
inherent in the components of the branch connection.
Sample problems illustrating the calculations for branch
reinforcement are shown in Appendix H.
(a) Nomenclature.
The nomenclature below is used
in the pressure design of branch connections. It is
illustrated in Fig. 304.3.3, which does not indicate
details for construction or welding. Some of the terms
defined in Appendix J are subject to further definitions
or variations, as follows:
b
p subscript referring to branch
d
1 p effective length removed from pipe at branch.
For branch intersections where the branch
opening is a projection of the branch pipe
inside diameter (e.g., pipe-to-pipe fabricated
branch), d1 p Db − 2 Tb − c ⁄ sin
d
2 p "half width" of reinforcement zone
p d1 or (Tb − c) + (Th − c) + d1/2, whichever
is greater, but in any case not more than Dh
h p subscript referring to run or header
L
4 p height of reinforcement zone outside of run
pipe
p 2.5(Th − c) or 2.5(Tb − c) + Tr , whichever
is less
Tb
p branch pipe thickness (measured or minimum
per purchase specification) except for branch
connection fittings (see para. 300.2). For such
connections the value of Tb for use in calculating
L
4, d2, and A3, is the thickness of the
reinforcing barrel (minimum per purchase
specification) provided that the barrel thickness
is uniform (see Fig. K328.5.4) and extends
at least to the L4 limit (see Fig. 304.3.3).
Tr
p minimum thickness of reinforcing ring or saddle
made from pipe. (Use nominal thickness
if made from plate.)
p 0, if there is no reinforcing ring or saddle
t
p pressure design thickness of pipe, according
to the appropriate wall thickness equation or
procedure in para. 304.1. For welded pipe,
when the branch does not intersect the longitudinal
weld of the run, the basic allowable stress
S
for the pipe may be used in determining th
for the purpose of reinforcement calculation
only. When the branch does intersect the
longitudinal weld of the run, the product SE
(of the stress value S and the appropriate weld
joint quality factor Ej from Table A-1B) for
the run pipe shall be used in the calculation.
The product SE of the branch shall be used
in calculating tb.
p smaller angle between axes of branch and run
(b) Required Reinforcement Area.
The reinforcement
area A1 required for a branch connection under internal
pressure is
A
1 p thd1 2 − sin (6)
For a branch connection under external pressure, area
A
1 is one-half the area calculated by Eq. (6), using as
th
the thickness required for external pressure.
(c) Available Area.
The area available for reinforcement
is defined as
A
2 + A3 + A4 ≥ A1 (6a)
These areas are all within the reinforcement zone and
are further defined below.
(1)
Area A2 is the area resulting from excess
thickness in the run pipe wall:
A
2 p 2d2 − d1 Th − th − c (7)
(2)
Area A3 is the area resulting from excess
thickness in the branch pipe wall:
A
3 p 2L4 Tb − tb − c ⁄ sin (8)
If the allowable stress for the branch pipe wall is
less than that for the run pipe, its calculated area must
be reduced in the ratio of allowable stress values ofthe
branch to the run in determining its contributions to
area A3.
(3)
Area A4 is the area of other metal provided
by welds and properly attached reinforcement. [See
para. 304.3.3(f).] Weld areas shall be based on the
minimum dimensions specified in para. 328.5.4, exceptthat
larger dimensions may be used if the welder
has been specifically instructed to make the welds to
those dimensions.
(d) Reinforcement Zone.
The reinforcement zone is
a parallelogram whose length extends a distance of d2
on each side of the center line of the branch pipe and
whose width starts at the inside surface of the run pipe
(in its corroded condition) and extends beyond the
outside surface of the run pipe a perpendicular distance
L
4.
(e) Multiple Branches.
When two or more branch
connections are so closely spaced that their reinforcement
zones overlap, the distance between centers of
the openings should be at least 11⁄2 times their average
diameter, and the area of reinforcement between any
two openings shall be not less than 50% of the total
that both require. Each opening shall have adequate
reinforcement in accordance with paras. 304.3.3(b) and
(c). No part of the metal cross section may apply to
more than one opening or be evaluated more than once
in any combined area. (Consult PFI Standard ES-7
for detailed recommendations on spacing of welded
nozzles.)
(f) Added Reinforcement
(1)
Reinforcement added in the form of a ring or
saddle as part of area A4 shall be of reasonably constant
width.
(2)
Material used for reinforcement may differ
from that of the run pipe provided it is compatible
with run and branch pipes with respect to weldability,
heat treatment requirements, galvanic corrosion, thermal
expansion, etc.
(3)
If the allowable stress for the reinforcement
material is less than that for the run pipe, its calculated
area must be reduced in the ratio of allowable stress
values in determining its contribution to area A4.
(4)
No additional credit may be taken for a material
having higher allowable stress value than the run pipe.
02/22/2012 6:29 AM
Thanks
Good Answers: 179
02/22/2012 8:02 AM
GA to mukes for an incredible answer.....
02/22/2012 9:29 AM
● Area located at ring (reinforcing pad), A41 = (OD - ID) * Thickness Tr * fr = (14 - 8.625) in. * 0.601 in. * (5700 psig / 8000 psig), where factor fr = Spipe / Spad
(Where, reinforcing pad thickness (ring), Tr = 0.687 (1-12.5%) = 0.687 (0.875) = 0.601 in.)
● Area of outward nozzle fillet weld, A42 = 2 Triangles = 2 * (1/2 Base * Heigt) = 2 * 1/2 * Leg2 = 2 * 1/2 * (0.354 in.)2 = 0.1253 in.2
where Leg of fillet weld = √2 * Throat tc (and it is easy mathimatically to proove that)
and from ASME B31.3, Para. 328.5.4(c), tc = lesser of 0.7 Tb or 0.25 in.
0.7 Tb = 0.7 x 0.500 in. = 0.35 in. & 0.25 in.
tc = lesser of (0.35 & 0.25) = 0.25 in.
Leg = √2 * tc = √2 * 0.25 = 0.354 in.
● Area of outer pad fillet weld, A43 = 2 Triangles = 2 * (1/2 Base * Heigt) = 2 * 1/2 * Leg2 = 2 * 1/2 * (0.486 in.)2 = 0.2362 in.2
where Leg of fillet weld = √2 * Throat (and it is easy mathimatically to proove that)
and from ASME B31.3, Fig. 328.5.4E(4) , the throat = 0.5 Thickness Tr = 0.5 x 0.687 in. = 0.344 in.
and Leg = √2 * throat = √2 * 0.344 = 0.486 in.
● Total area of fillet welds = A42 + A43 = 0.1253 + 0.2362 = 0. 3615 in.2 ≈ 0.362 in.2
Notes:
- Run thickness, Th = 0.687 (1-12.5%) = 0.687 (0.875) = 0.601 in.
- Branch thickness, Tb = 0.500 (1-12.5%) = 0.500 (0.875) = 0.438 in.
Where 12.5% is the mill tolerance as per specification of ASME B31.3
05/30/2014 8:18 AM
can you do the excerise of one question? So i can have a better understanding.
Dia header 10
Dia branch 4
Material ASTM A53 grade B.
Header & branch schedule is 20
Thanks in advance.
Register to Reply 8 comments
Abdel Halim Galala (1); CaptMoosie (2); Crabtree (1); Jahangir (1); Mukesh0861 (1); passingtongreen (1); shan123 (1)
