Previous in Forum: Slug Catcher Design   Next in Forum: Steam Coil Tracing - Hydrostatic Or Pneumatic Test
Frictional Loss Vs Viscosity
02/22/2012 10:32 AM
Hi,
Could you tell the physical reason why the friction factor comes down as the Renold's number(Re) increases (for flow over a plate as well as flow through pipe). From equation Friction factor(λ) = 0.3164 / (Re)^ 0.25 it is visible, but please tell the physics behind that. (like heat transfer coefficient which follows same trend,becoz of, temperature variation between adjacent molecules becomes lesser & lesser)
And, friction loss through a pipe is greater for air flow case compared to water flow (for same volume flow rate & same pipe) though the dynamic viscosity (which is directly proportional to shear stress) of water is greater than air, why so?
Re: Frictional loss Vs Viscosity
02/22/2012 10:53 AM
At high Reynolds Number, the flow is such that the velocity gradient produces turbulence near the boundary. The bulk of the flow is largely lacking in turbulence. As the velocity increases further, the velocity gradient near the walls steepens and the cross-section of the bulk flow widens, so the Friction Factor, which relates the pressure drop to the velocity goes down.
In the water-air comparison, viscosity is in the divisor of the Reynolds Number, so lowering the viscosity increases the Reynolds Number.
In laminar flow in pipes, the density term in the Reynolds Number is cancelled-out by the density term elsewhere in the Darcy-Weisbach equation, so viscosity rules, and pressure drop will increase with viscosity to the power of 1.0. Increasing the Reynolds Number into turbulent flow increases the pressure drop in accordance with the equation you have stated; this time, viscosity leads to the power of 0.75 .
Not bad for a polooceman, eh?
Good moaning!
Reply Good Answer (Score 4)
02/22/2012 11:23 AM
I'm impressed!
