Previous in Forum: Selection of Gate Valve Trim Assuming Same Design Conditions   Next in Forum: Chaining Pressure Vessels and Outlet Temperature
Characteristic Number on Bearings
02/25/2012 5:56 AM
how to estimating the characteristic number on bearings
Pathfinder Tags: bearings
Re: characteristic number on bearings
02/25/2012 6:59 AM
It is also called sommer field number.
The Sommerfeld Number is
S = \left( \frac{r}{c} \right)^2 \frac {\mu N}{P}
Where:
S is the Sommerfeld Number or bearing characteristic number
r is the shaft radius
c is the radial clearance
μ is the absolute viscosity of the lubricant
N is the speed of the rotating shaft in revs/s
P is the load per unit of projected bearing area
02/25/2012 7:48 AM
... or:
Re: Characteristic Number on Bearings
02/26/2012 10:30 AM
Sommerfeld number> 1 occurs in heavily loaded bearings at the
limit for b/d: 0 < b/d ≤ 2
Sommerfeld number < 1 occurs in high speed bearings at the
limit for b/d: 0.5 < b/d ≤ 2
d : bearing diameter
b : bearing width
Register to Reply 3 comments
JohnDG (1); Mukesh0861 (1); thinkhigh (1)
