Previous in Forum: Level Calculation   Next in Forum: Hardness Tester
What is Superimposing?
02/27/2012 7:52 AM
what is defnition of superimpose? anybody can explain?
India - Member - Naveen Menon Engineering Fields - Instrumentation Engineering - Naveen Menon
Re: instrumentation
02/27/2012 7:54 AM
su·per·im·pose/ˌso͞opər-imˈpōz/
Verb:Place or lay (one thing) over another, typically so that both are still evident.
Synonyms: superpose
More info »Dictionary.com - Answers.com - Merriam-Webster - The Free Dictionary
Re: instrumentation
02/27/2012 8:31 AM
Sir be specific about what you want to say, in what context you are askin for that will be clear to give me your answer
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: What is Superimposing?
02/28/2012 6:04 PM
To "superimpose" two things is to add them together. The Superposition Theorem in circuit analysis is a good example of this, where you analyze a multi-source circuit once for each power source, then superimpose all the voltages and currents obtained in those analyses to determine what the sources will do when they're all active at the same time.
A practical example of superposition used in instrumentation is HART circuits, where the DC 4-20 mA analog signal is superimposed with the AC HART FSK "tone" waveforms along the same pair of wires. Using filter circuits we can separate the DC signal from the AC (HART) signal, but they exist together on the same cable as a superposition (a combination of AC plus a DC offset).
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Register to Reply 3 comments
leeb (1); naveen_menon (1); tonykuphaldt (1)
