Previous in Forum: Why it is Current?   Next in Forum: Where Can I Get RS232 to RS485 Converter in Phnom Penh?
Removal of Write Protection from USB Flash Drive
03/05/2012 2:42 AM
Pls i need help on how to remove Write Protection from my 16GB SONY VAIO USB2.0 Flash drive. I have tried Formatting by explorer and by command Prompt but it doesnt work, i tried deleting the files in it one after the other but it doesnt seem to work.
Desire! That's the one secret of every man's career. Not education. Not being born with hidden talents. Desire. - Bobby Unser
Pathfinder Tags: Computer Systems
Re: Removal of Write Protection from USB Flash Drive
03/05/2012 7:57 AM
Did you get one of these?
Maybe some help here.
03/07/2012 9:07 AM
The flash i have is exactly like i have seen meaning it is fake... but isnt there something i can do to remove the write protection atleast i have been using the usb flash drive for a while now. Something with command prompt or registry editor or something
Good Answers: 44
03/06/2012 11:53 AM
If you are deleting files, then you are writing to the drive...
What are the symptoms...as in...what makes you think it is "write-protected"?
Maybe it's just broken?
03/07/2012 6:06 AM
whenever i try deleting, formatting, checkdisking and al, it says i should remove the write protection
Good Answers: 44
03/07/2012 10:59 AM
1. Remove USB drive
2. Start REGEDIT
3. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
(if the above key does not exist, create it)
4. Double click the key "WriteProtect" from the right side and set the value to 0 (zero)
(again, if the first key doesn't exist then this value will need to be created)
5. Press OK
6. Exit REGEDIT
7. Restart computer
8. Re-connect USB drive
This should fix it (unless it really is one of those cheap knock-offs, then the problem exists on the thumb drive).
cuba_pete (2); kramarat (1); Smart (2)
