Previous in Forum: How to Measure and Control the Temperature   Next in Forum: Resistor Value
I Want 20 RPM Speed
03/05/2012 8:26 AM
i want 20rpm speed with the motor then please tell me the specification of the motor
Re: i want 20rpm speed
03/05/2012 8:35 AM
300 poles for 50Hz operation. 360 poles for 60Hz.
You're welcome.
03/05/2012 8:38 AM
On a more serious note, you haven't given anywhere near enough information to be able to specify a motor.
Hint: you'll almost certainly need a gearmotor.
Re: I Want 20 RPM Speed
03/05/2012 9:50 AM
You could use the drive from the minute hand from a battery clock, sped up through a 20:1 gearbox.
Or, you could drive the shaft from the second hand with a 3:1 step down gearbox.
Actually, the possibilities are endless given such a loose specification, Guv, as #2↑ implies.
Good moaning!
03/05/2012 1:44 PM
03/05/2012 1:47 PM
Contact one of the thousands of motor suppliers at Search GlobalSpec.
They will be thrilled to help you.
05/15/2012 7:38 AM
hello nhadkine, if you want your motor run in 20 rpm you need to get VFD variable freqency control and here is the website, http://www.vfdmotor.us/motorspeedcontrol.html im sure this will help you to slow down your motor !!!
i want ot helf piple need assistance and to share my knowleged in technical
Register to Reply 6 comments
Crabtree (1); JohnDG (2); lyn (1); toink (1); wareagle (1)
