Previous in Forum: Resistor Value   Next in Forum: C T Connection
9 comments
Instrumentation Problem
03/05/2012 4:10 PM
The equations governing the motion of a moving coil loudspeaker/microphone can be expressed as
Where:
x is the displacement of the microphone cone m
V is the applied voltage V
i is the current through the coil A
F is the external force N
P is Pressure Pa
m is the mass of the cone 10-4 kg
r is the resistance to motion 5 Nsm-1
s is the compliance of the cone 10-6 mN-1
is the length of the wire on the coil 10 m
L is the inductance of the coil 1 mH
B is the magnetic field 0.1 T
R is the electrical resistance of the coil 5 kW
A is the area of the cone 10-4m2
e is the pickup noise V
a) The microphone is connected to an instrumentation amplifier with an input impedance of 5 kW and a gain of 100dB. Given that the inputs are pressure and pickup noise and the output is the amplifier voltage derive either a pair of transfer functions OR a state space representation of the system.
b) Using Matlab determine the bode response if the system to both Pressure and electrical pickup noise. Comment critically on your results, explaining the major features of the plot.
c) Convert the system to a Simulink block and determine the rms amplitude of response to a sound wave of pressure 10-2 Pa at 200Hz. Compare the resultant with part b).
2) The microphone is used to measure the acoustic noise from an induction motor in an area of high electrical interference (50 Hz) and broadband white noise. The motor is running at 2400rpm and produces noise both at this frequency (fundamental) and at harmonics up to 600 Hz and is analysed using a PC.
a) Determine a suitable sampling frequency. Design a notch filter to remove the 50Hz component, paying particular attention to any assumptions you have made in the design.
b) Implement the filter in Matlab and determine the bode response of the system and comment on your results, particularly the width of the notch.
c) Implement the filter in Simulink and using a signal source containing both 50Hz and 55Hz of rms amplitudes 1 and 0.1 respectively. Determine the output of the filter and comment critically on your results.
3) The dataset en311_03.mat (available in the unit box) contains information on the pressure, noise level of the workshop in which the induction motor/microphone is placed.
a) Using both the microphone model and filter model implement a instrumentation system in Simulink to measure the rms voltage.
b) Modify the system such that an alarm is triggered if the rms voltage level from the microphone is twice that of the value in part a).
Re: Instrumentation problem
03/05/2012 4:34 PM
I am a third year student doing my finals, I must have misunderstood this site, sorry lyn, my notes and books have all the answers but lectures are very busy now. That is why I signed up on here for abit of a push in the right direction.
03/05/2012 4:36 PM
Good luck!
Good Answers: 183
03/05/2012 5:19 PM
Very nice problem you will learn a lot solving it on your own!
Re: Instrumentation Problem
03/05/2012 7:07 PM
Oooh - do you see what the rest of us do?
Please save images to your PC, and post to CR$ from your saved files. Otherwise, we'll all see stuff like my post above. It may look good to you, but not to the rest of us.
03/06/2012 1:37 AM
F+Bil = m(d2x/dt2) + r(dx/dt) + (x/s)
F = PA
V - Bi(dx/dt) = L(di/dt) + Ri + e
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
03/17/2012 7:45 AM
R is the electrical resistance of the coil 5 kW.
How it can be 5KW ?
If you can't find a way, make one........
Good Answers: 183
03/17/2012 12:15 PM
Because when in word you use the "symbol" font "Ω" is the "W" on the keyboard.
03/17/2012 12:38 PM
Yes the last comment is right, nearly halfway there, matlab 7.10.0 is helping though, the maths isn't the problem, its the software, i have the maths solution.
Register to Reply 9 comments
JohnDG (1); justinanto1987 (1); Leidau (3); lyn (2); nick name (2)
