Previous in Forum: Why the Current Ratings Are Not Same   Next in Forum: Lightning Protection System
11 comments
Reasons for Damage/Burning of Distribution Transformers
03/07/2012 1:00 AM
What are the significant reasons for burning/damage of distribution transformers? What could be the remedial measures?
inhussain
Good Answers: 181
Re: Reasons for damage/burning of distribution transformers
03/07/2012 4:32 AM
It's better when you do your own homework.
03/07/2012 4:55 AM
Will you please eloborate 'Homework' for the benifit of viewers and members of this forum
inhussain
United States - Member - New Member Hobbies - Automotive Performance - New Member
03/07/2012 11:45 AM
This isn't homework, he's asking a question. If you don't have an answer, why bother?
03/07/2012 6:45 AM
CR4 ADMIN: Deleted Post
Abuse/Attack: This post was deleted because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
Re: Reasons for Damage/Burning of Distribution Transformers
03/07/2012 8:19 AM
The simple answer is no or improper maintenance. Go through manufacturer's literature.
pnaban
03/07/2012 11:00 AM
I expect technical deliberation from the learned members of this forum instead of astraying from the thread.
inhussain
New Zealand - Member - Kiwi
Good Answers: 29
03/07/2012 2:30 PM
Expectations can be very dangerous things.
Here, the quality of the answers can be taken as a reflection of the quality of your question. If you ask a vague, general question such as in your OP, the responses you get will reflect that vagueness and generality. If, however, you ask a more specific question that shows that you have already done a bit of research, you will ge a ton of helpful answers.
paulusgnome
Good Answers: 11
03/07/2012 12:25 PM
You need to provide more information about failures.
Failures could be anything from someone shooting a bullet through the transformer to poor transformer design to overloading to old age.
03/07/2012 11:56 PM
Apart from general reasons, like overloading, unbalancing, improper earthing,penetration of moisture, etc. the present day load pattern like use of CFLs and other electronic loads, harmonics are produced travelling towards the transformers. The third harmonics has a significant contribution towards distortion of wave shape; that does not remain sinosidal rather distorted. It has significant impact on the core performance that needs to be studied. Further, the the use of CFLs would reduce the Power factor of the system; the affects thereof also need to be studied. Hoping my friends would comment accordingly keeping in view my submission.
inhussain
03/08/2012 3:25 AM
Inadequate circuit protection arrangements are the principal reason, Guvnor, followed by a regime of inadequate maintenance.
Good moaning!
03/09/2012 10:33 PM
there are no significant reasons bcoz everything can be significant, even small stuff could buy you a problem. here i give some reason :
first, unbalance load. in my country a distribution transformer is three phase transformer but each phase is loaded individually due to household voltage requirement wich we know mostly is single phase load. if for some reason the load in each phase is unbalance above it's service factor, it can cause damage
second, dirty post insulator. if a transformer is installed in dusty environment, the dust could cover the insulator and cause severe short circuit
third, dirty oil transformer (certain transformer). every oil transformer hast it's own lifetime due to it's liquid material. if a transformer is energized, the oil prevents it from short circuit between each phase by dissipating the electron leaps. this process creates small bulb/foam which will accumulate (some transformers equipped with silica gel to absorb this bulb/foam, it's color will change from original blue/violet to light blue from time to time as it absorbs the foam). and i guess you know what will happen if the foam accumulates above it's reasonable level. the foam contains oxygen which will react with oil transformer, creates sulfur film covering the conductive rod in each phase which means shorten the gap between each phase and bang....!!! there you go short circuit
that's all i know, hopefully it's helpfull
Register to Reply 11 comments
Anonymous Poster (1); Baxter (1); bolang (1); Carl Pugh (1); Crabtree (1); inayat hussain (3); Paulusgnome (1); pnaban (1); TonyS (1)
