Previous in Forum: Rating of Generator Panel   Next in Forum: How to Find Out the Current Taken By Long Tranmission Over Head Lines
11 comments
Electrical Earthing Point Labelling
03/08/2012 4:56 AM
Hi there, is there any type of labelling for earthing pit point to differentiate between main electrical, telecommunication or lightning protection?
Re: Electrical earthing point labelling
03/08/2012 5:00 AM
What does your local wiring code say? You ARE working to the appropriate national standard, aren't you?
Good moaning!
03/08/2012 5:53 AM
not really specified in national standard. It is more for easier future maintenance.
Anonymous Poster #2
03/08/2012 5:22 AM
Use "Earth pit"...and dont use " Anonymous Pit"
03/08/2012 5:59 AM
yeah! earth pit but after few years, new maintenance guy come, can he identify which one for main earth point, which for communication etc.. just by looking at it.
03/08/2012 6:02 AM
That's what "as built" drawings are for.
The worst ink survives the best memory. - Anon
Good moaning!
03/08/2012 6:05 AM
Ok, as built is the 1st choice,
other option which is faster reference
Anonymous Poster #2
03/08/2012 6:09 AM
First make a schedule of numbering/identification for all of your Earthpits including, communication, main earth and Lightning protection. Give some abbreviation such as EP for main eath, LP for lightning protection etc...Then please fix the identification label on the Earth pits..
03/08/2012 6:30 AM
Now why didn't I think of that?
Good moaning!
Good Answers: 58
Re: Electrical Earthing Point Labelling
03/08/2012 12:07 PM
Your term "earthing pit" leads me to assume that you are talking about one of these or something similar:
If so, why not stamp the cover with the type of ground system and location (in case covers get mixed up)?
Top of rod can also be stamped with a small 3 digit code (after installation of course) that can incorporated onto the as-builts.
You can also color code each system with a quality industrial paint or epoxy but re-coating will be required periodically.
03/09/2012 5:52 AM
KJK, in my case we are using concrete pit. Well, painting is easier one but of course need re-coating over time.
Is there any other type of labelling sell in the market or had been used in your country or anywhere in the world.
Tq.
03/09/2012 1:42 AM
Let me put this, this way around, what we have done in that situation, our drawings were pretty much clear about
Electrical Earth pit - Dirty earth/Power Earth (PE).
Telecommunication Earth Pit - Intrinsically safe Earth pit (IS)
Lighting load earth pit- Non Intrinsically safe Earth pit (NIS)
So, we have three systems PE,IS,NIS
Eventually, all circuit will be routed to ground only, this arrangement help us to direct lighting strokes, surge, transient to ground directly without routed to another system.
For this we have separate earth bar for each system, and that is the real headache in the big industry/refinery/oil and gas stations if we are working on existing system.
Am Ali (4); Anonymous Poster (2); Crabtree (3); harjeetsinghengg (1); KJK/USA (1)
