Previous in Forum: Volvo Penta Code Reset   Next in Forum: Ignition Coils
UV Mini-Lamp Power Supply
03/11/2012 11:36 AM
UV lamp (Grainger# 2EWY8) used in 2EWX9 12V car unit ($140+). I just want the ?exciter? & power for the lamp for a small water UV device in the solar boat's water circulation line. Lamp is 85mm X13mm X4mm & will slip into sealed Pyrex test tube for its use. Lamp has a micro drop of mercury inside. I can cannibalize 2EWX9 but rather build off a less costly/destructive 12/24V compact solution. Is there a somewhat common starter for these lamps?
Re: UV Mini-Lamp Power Supply
03/15/2012 1:32 PM
Oh, I don't know. Ring these people instead of asking me: http://www.grainger.com/Grainger/UV-Lamp-2EWY8
Innuendo is not Italian for a suppository.
