can anyone help me with the information on how to simulate the cyclonic wet scrubber that i designed for my project. actually i would need the simulation softwares if possible thanks.
How did you design it ? In general when making a design one has first to simulate the function and according to results define dimensions and other parameters as for instance ratio air/fluid, diameter, air tangential velocity and many other. If you do not have computed those values (which is a process simulation) I do not understand how you were able to design it. May be you developed a new path in design and it would be of interest to all to get the information.
