Previous in Forum: Homebuilding of Jet Drive Mod to 10hp Outboard   Next in Forum: Calculating Size of a TEG to Power Load 'xyz'
NPT Thread Pressure Rating Calculation According to ASME B31.3 Code
03/14/2012 6:32 AM
Dear all!does any body know how to calculate the pressure rating of NPT thread based on thread material and thread size .and what are the requirements for thread sealant ?
Good Answers: 38
Re: NPT Thread Pressure Rating Calculation According to ASME B31.3 Code
03/15/2012 8:05 AM
Maffoud....
NPT or National Tapered Pipe Threads are NOT pressure rated like ASME flanges.
The experienced pipe fitter simply ensures that he has a well cut pipe thread, removes metal burrs, uses a lubricant (or PTFE pipe tape)....then snugs up the joint. Because these are tapered threads, once the joint begins to engage, it quickly tightens in a fraction of a turn.
Cutting threads in pipe requires a Schedule 40 or higher rated pipe. Schedule 10 or 10S piping is not suitable.
The pressure rating of the system us determined BY THE THREADED FITTING..... NOT BY THE NPT JOINT.
More information can be found in Wikipedia under NPT pipe thread.
You do have an experienced piping engineer to answer your questions in your organization ..... right ?
