Previous in Forum: The Rights of Speaker or the Rights of Listener?   Next in Forum: Electrical Characteristics
Serial Communication
03/14/2012 12:53 PM
I want to do serial communication between two computers using laser. for that i wish to write a c program for fixing baud rate, number of parity bits etc and i also want to include my data to be transfered in that program. where i should load my program in my computer?
Re: Serial Communication
03/14/2012 1:25 PM
You won't need a C program to do this. A program will just consider all of these parameters as just numbers to be loaded into a register.
Good Answers: 69
03/14/2012 5:24 PM
That is correct, what he can do is add a transistor to the TX driver to pulse a laser diode, and connect a phototransistor to the RX input to receive the laser beams, will need two such circuits.
I wander how's he gonna manage to aim the two transceivers...
Regards
03/14/2012 5:29 PM
Figure 7. A sample code listing in Borland C++ 3.1 that can be used for full-
duplex communication between two computers. The program can be used to test a
single transceiver simply by pointing the laser at the photo-transistor.
** Laser Pointer RS-232 Transceiver
** Copyright (c) 1997 GKDesign
** 24th May 1997 George Katz
** Data Transmitted @ 9600 bps
#include <dos.h>
#include <stdlib.h>
#include <conio.h>
#include <bios.h>
#include <stdio.h>
#define COM1 0
#define COM2 1
#define DATA_READY 0x100
#define TRUE 1
#define FALSE 0
#define ESC_KEY '\x1b'
#define SETTINGS ( _COM_9600 | _COM_CHR8 | _COM_NOPARITY | _COM_STOP1)
void clear_line(int line)
int i;
gotoxy(1,line); // clear a whole line
for(i=0;i<80;i++)
printf(" ");
int main(int argc, char *argv[])
int in, out, status, done = FALSE;
int curs_rx=0,curs_ry=15,curs_tx=0,curs_ty=4;
int com_port=COM1;
if (!(argc == 2 && (argv[1][0] == '2' || argv[1][0] == '1')))
printf("Usage: LASER [1|2]\nwhere 1 = Com port 1\n 2 = Com port
2\n");
exit(-1);
if (argv[1][0]=='2') // select com port
com_port = COM2;
else
com_port = COM1;
bioscom(_COM_INIT, SETTINGS, com_port); // Initialize serial port
clrscr();
printf(" GKDesign (c) 1997 Laser Transceiver Communicator
V1.1\n");
printf(" Press [ESC] to exit program\n");
printf("__________________________________ Sent Data
___________________________________");
gotoxy(1,13);
printf("________________________________ Recieved Data
while (!done) {
dUmMy= bioscom(_COM_STATUS, 0, com_port); // recieved data?
if (status & DATA_READY)
if ((out = bioscom(_COM_RECEIVE, 0, com_port) & 0x7F) != 0) { //
get data
if (curs_rx < 78) // move cursor
curs_rx++;
else {
curs_rx = 1; // at end of line
if (curs_ry < 23)
curs_ry++;
else
curs_ry = 15;
clear_line(curs_ry);
gotoxy(curs_rx,curs_ry); // goto correct screen location
putch(out); // print the character
if (kbhit()) {
if ((in = getch()) == ESC_KEY) // check for ESC key
done = TRUE;
if(!in) // read an extended character
in = getch();
if (curs_tx < 78) // position cursor
curs_tx++;
else {
curs_tx = 1; // at end of line
if (curs_ty < 12)
curs_ty++;
else
curs_ty = 4;
clear_line(curs_ty);
gotoxy(curs_tx,curs_ty); // goto correct screen location
putch(in); // print the character
bioscom(_COM_SEND, in, com_port); // output data
clrscr();
return (0);
http://www.qsl.net/n9zia/wireless/laser/laser.htm
04/03/2012 2:48 AM
sir, if i am using ubuntu terminal for executing above code in transmitter pc then where i can view in the receiver pc?
Register to Reply 4 comments
neenajoy09 (1); redfred (1); SolarEagle (1); Yahlasit (1)
