Previous in Forum: Defining Through Transmission Welding (TTLW)   Next in Forum: Battery Tester
How to remove PowerPoint password quickly?
03/15/2012 2:47 AM
PowerPoint password is widely used in office work.
PowerPoint is used to create slideshows, on-screen projections, for printing or web based displays. Especially, it is widely used in office work and many people would like to password to prevent others from copying or viewing the important information in the file.
Forgetting PowerPoint password is very normal.
For every day, we have so many things to do and to remember that we are easy to forget the PowerPoint password, if we forget the PowerPoint password someday, it will be very normal. In this case, you would like to try PowerPoint password remover for removing your PowerPoint password. While Smartkey PowerPoint Password Recovery 5.0 that supports PowerPoint2002 to 2007 can safety and effectually help you PowerPoint password removed if you forgot your PowerPoint password.
How to remove PowerPoint password by Smartkey PowerPoint Password Recovery 5.0 tool? You can follow the following steps.
Step1: You need download Smartkey PowerPoint Password Recovery 5.0 tool from Smartkey, and install it.
Step2: Click "Open" button to find out your forgot password PowerPoint Password file to the program, then select your file in the Open File window and click "Open".
Step3: About passwords-to-open, PowerPoint Password Recovery 5.0 provides three different searching methods that are "advanced dictionary attack", "brute-force attack", and "advanced brute-force with mask attack" for us, while you can select the method according to your situation. Generally, we select "Brute-force Attack (Trying All Possible Combinations). When you finish selecting, you will Click "Start" button in the Menu to initiate the program.
Step 4: After a moment, a messenger that the opening password is recovered successfully and you can use it to access the files freely. Click "Remove all Password from the File" to remove all passwords from the file, including the opening password and write protection password, Thus you can access and edit the file without and password will be saw, then you do as the suggestion .
All in all, PowerPoint Password Recovery 5.0 is an easy-to-use tool designed for removing PowerPoint password. If you forget your PowerPoint Password in the future, don't worry about it, Smatkey PowerPoint Password Recovery 5.0 can help you remove PowerPoint password effectually and safety.
Related Article:
How to Break Office Documents Password?
Related Source:
http://www.recoverlostpassword.com/article/remove-ppt-password.html
