Previous in Forum: Use of 5P10 Class CT Instead of PS Class CT   Next in Forum: Power Factor
types of testing on motor's before commissioning
03/15/2012 1:11 PM
hi frnds
Tdy i have seen in my plant they are testing the motors with vibrating tester, Pls some one could tell what all the testing types, testing methods or procedures before commissioning the motors....
Re: types of testing on motor's before commissioning
03/15/2012 1:15 PM
Oh, I don't know. Why don't you ask the "they" that are doing the work?
Innuendo is not Italian for a suppository.
03/15/2012 1:24 PM
Maybe they're just playing a little melody.
03/16/2012 6:48 AM
I think cold test(continuity and meggaring test) is better way to start with ,as far as electrical part is concerned,....other tests u can check bearing by rotating conductor manually and check for stiffness .Finally u have to energize at least for 2 hour continues see how it rotates and see heating ...i think u will get necessary technical observation there
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
03/18/2012 6:35 AM
If you need you can do,
1) Insulation & Continuity test
2) No load test
3) Full load test
4) Vibration Analyzing
No load test and full load test will conduct after the manufacturing of motor.
You can ask factory for the report.
If you can't find a way, make one........
Register to Reply 4 comments
Horrible Old Bat (1); justinanto1987 (1); redfred (1); sunday matembo (1)
