Previous in Forum: The UK is Getting Smaller   Next in Forum: Asterioid Near-miss Predicted - February 15th 2013
Rejuvenating Rubber Refrigerator Seals
03/16/2012 2:42 AM
My draft refrigerator seals are getting stiff. I was considering softening them by wiping them down with brake fluid.
Does anyone have an opinion or suggestion?
Re: rejuvenating rubber refrigerator seals
03/16/2012 3:00 AM
You can use a silicon spray, but it depends how far gone they are....You can also buy gasket replacement sets...I wouldn't use brake fluid or any petroleum product...
Re: Rejuvenating Rubber Refrigerator Seals
03/16/2012 7:44 AM
Good Answers: 58
03/16/2012 12:35 PM
'Armor-all' is a good product, seems to clean and protect plastics.
mike k
Good Answers: 137
03/16/2012 3:18 PM
How about Waxoyl? It's claimed to stop rubber cracking.
Good Answers: 120
03/16/2012 10:45 PM
brake fluid will probably turn them into a sticky mess. You can test with one drop on the top of the door??
Replacement gaskets are a common item.
Gaskets
Per Ardua Ad Astra
03/17/2012 12:06 AM
Your seals are not made of rubber. They are a vinyl compound. Your best bet is to contact the manufacturer of the Refrigerator and ask their technical department. The suggestion of using Armoral is probably the best suggestion so far. I worked as a sales person for General Electric appliances and found that most companies are willing to go out of their way to be helpful
A hand without an arm is a useless tool
03/19/2012 1:10 AM
You ere not rejuvenating your lungs...
Change the seals !! It is better to seal the refrigerator with proper elastic seals...
aurizon (1); Byron Jay (1); Codemaster (1); Jacob Klepatch (1); kramarat (1); mike k (1); SolarEagle (1)
