Previous in Forum: Battery Tester   Next in Forum: We supply cranes, loaders,dozers,rollers,excavators etc
How Can I Ensure I Select The Right Bearing
03/16/2012 8:43 AM
The selection of the proper bearings for all mechanical systems is essential to the functional and commercial success of that system. The bearings must not only be of the correct functional type and size, but also the right material and have the proper lubricant to ensure reliability, efficiency, and cost effectiveness. The bearings must be matched to the operating environment and handled and installed correctly for the system to be successful.
At AST, selection of the best product goes beyond the part's type, size, material, and lubricant. Our application engineering team evaluates a number of conditions to determine the optimal recommendation. These considerations include, but are not limited to:
  • Stack up tolerances
  • Material selections based upon the operating environment
  • Mating tolerances and materials
  • Proper bearing installation including appropriate tools
  • Expected life
  • Maintenance requirements
  • Need and impact of seals and shields on performance
  • Lubrication type selection
  • Lubrication quantity/fill amount
  • Re-lubrication method
  • Application of barrier film
While the detailed specifications found on our web site along with AST's technical documents are intended to provide you with as much information as possible for you to make the appropriate choice for your application, it is impossible to cover all aspects of bearing selection due to the vast number of variables involved. Depending on your application, AST's application engineering team will employ a wide range of criteria and selection parameters to ensure you select the best possible product for your design.
If you have another question for us, just let us know and we will do our best to provide you a prompt and accurate answer.
For various Engineering tools you can check our products for various purpose like of
Hardness conversion
Re: How Can I Ensure I Select The Right Bearing
03/16/2012 9:36 AM
We didn't have a question for you in the first place.
This belongs in the commercial section.
03/16/2012 11:08 AM
But how can one select the correct bearing when all the questions the vendor asks makes no sense to the one looking for a bearing? Unless the OP can answer that question, this thread should vanish into the commercial void.
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
03/17/2012 12:11 AM
You are starting off on the wrong foot. Commercial ads are not to be posted in the discussion forums.
Speak softly and carry a big stick.
Good Answers: 29
03/17/2012 12:33 AM
Sounds like you guys need a starting gun...for the race!
09/24/2012 10:32 PM
Really good and informative... kindly add some pictures for better understanding.
Thanks
jmmyadam (1); lyn (1); RDGRNR (1); redfred (1); standarded (1)
