Previous in Forum: Lowrey Organ Rumbling Pedal Notes   Next in Forum: Testing Troubleshooting Ability?
35 comments
Solid-Fuel as a Direct (Non-Gasified) Fuel for Gas-Turbines?
03/17/2012 9:31 AM
Okay, I know it's difficult enough to get liquid fuels to combust completely uniformly in many circumstances that a heat engine is used, but as flour mill explosions illustrate, a fine enough (hydrocarbon) dust in perfect circumstances will lead to pretty effective release of energy (of course, explosions are a one-shot supersonic event, whereas combustion is ideally a continuous, metered subsonic condition, but still...).
I'm sure this must have been experimented with during the age when coal was king, but I can't find any references to it at present.
Admittedly raw coal (or even coke) would not appear to be a nice fuel because of the ash content, but using charcoal or torrefied wood (than can be easily co-fired with coal) as an alternative could, on the face of it, be a far more manageable fuel as it can be pulverised with similar ease as coal.
Re: Solid-fuel as a direct (non-gasified) fuel for Gas-turbines?
03/17/2012 9:57 AM
Thats basically how a coal fired power plant boiler works. They crush coal into a very fine powder and blow it into a massive combustion chamber and burn it in mid flight.
If you want more details find a coal fired power station and take a tour. Many do that as part of their public relations programs. Or at least around here in North Dakota they do. I have been on a number of tours now and its very interesting!
03/17/2012 10:07 AM
What you're describing is a coal-fired steam-turbine, surely? Steam turbines are a type of external heat-engine.
My Q relates specifically to an Internal-combustion machine - like gas turbines (or Otto cycle, etc).
03/17/2012 10:24 AM
There has been investigations of a Brayton-cycle coal fired plant in the form of a magnetohydrodynamic generator. This is one way to circumvent the substantial problems associated with pushing fly ash through a combustion turbine.
03/17/2012 10:43 AM
Interesting.
However fly-ash is produced in far lower quantities from biomass fuels, but that's not me saying it's not a problem. ... So the quality of the fuel is key as I see it.
03/17/2012 11:05 AM
'....So the quality of the fuel is key as I see it....'
Ash would be a big obstacle for combustion turbine attempting to utilize coal or wood or similar fuels.
What advantage are you hoping to gain by eschewing tried and true boiler technology?
03/17/2012 10:53 AM
Too much ash is generated with coal or wood to be practical in an internal combustion engine...You do have your solid rocket fuel engines...
03/17/2012 11:00 AM
How about pulverised charcoal, which is much lower in ash?
And could a chemical agent reduce the ash forming components to near zero?
I'm not asking if it's economical, I'm asking could it be done?
03/17/2012 11:14 AM
'...I'm not asking if it's economical, I'm asking could it be done?...'
Definitely.
03/17/2012 12:23 PM
Excellent!
Can you tell me what chemicals are needed to 'clean' the ash out of charcoal?
03/17/2012 1:12 PM
When you asked if it could be done without regard to economic efficiency, the need for clean fuel was no longer important since there are numerous solutions when no financial restraints are imposed.
The low availability and high costs of burning an ash producing fuel in a combustion turbine becomes a non-issue with a budget that allows for extended downtime, frequent and extensive maintenance and high capital costs for frequent new components.
Another non-budget restricted solution might be something like steam reformation of pulverized coal with the goal of producing purified a gaseous fuel. I haven't looked at that type of thing in a long time, and there must be significant problems, otherwise the cheap price of coal certainly have lead to attempts to provide an alternative to gasoline....
03/17/2012 1:41 PM
So, if I may paraphrase, are you saying that the reason, independent of initial investment in experimental plant or fuel processing for testing with solid fuels throughout the coal age is because it was just damn obvious that any design would be wrecked in almost no time at all? I can imagine them saying "no need to build that scale model, it's clear as day it'll be broke within the week!".
03/17/2012 2:34 PM
It isn't as if there was no data on which to go...
Gas and diesel engines gunked-up (technically speaking) over long periods from things like fuel contaminants, blow bye, EGR valves, bad air filters and poor maintenance habits, provide a decent insight into the woes that coal and wood fired ICE would develop in a much shorter period of time.
Damage to turbines due to particulate or liquid impingement is well studied.
Planes aren't too reliable when attempting to pass through volcanic ash.
Around a camp fire, if your marshmallow or hotdog on a wobbly roasting stick momentarily dips just the end into the wood ash below but distracted you do not notice and eventually take a bite. That entire night as you marvel at how in blazes there can still be grit in your mouth, it might become more clear why ash generating fuels are not very compatible with combustion turbines.
The smokestacks of coal fired boilers would also give an indication of the type and degree of fouling that would present such an enormous and constant problem.
so, yeah 'no need to build a scale model'
03/17/2012 5:02 PM
Er, ...thanks! *wry smile*
Although GTs can take a small amount of water vapour through - about 5% by volume IIRC. I remember reading that pumping in small amounts of distilled water just before the combustor will lower the temp and stop NOx forming.
*NB. May count as off-topic*
Anyway, so as you say, I won't bother building any SF-GT models anytime soon!
03/17/2012 11:48 AM
Coal oil. Coal liquefaction - Wikipedia, the free encyclopedia
It's easier to pump the liquid stuff out of the ground, for now.
WOODGAS POWERED VW'S AND OTHER VEHICLES
03/17/2012 12:21 PM
No doubt - 'stuff' in the ground is what the last two plus centuries have been all about!
It might be kinda wrong to ask on an engineering forum what [i]can[/i] be done if not also asking would anyone think it's an economic thing to do in the foreseeable future.
I have a little knowledge (a dangerous thing, they say) of Coal liquefaction, fast pyrolysis and wood gas. It's just it seems that none of those techs or the many others are quite right for smaller-scale applications. Take woodgas vehicles for example, you have to lug a whole trailer (or bed) of gizmos around to run on it. The fuel is low density and, even dry, contains alot of water (that's not fuel in anyones book, unless your name's Stanley Mayer!).
Am having a pop at thinking outside the box, without I hope loosing my grip on reality!
03/17/2012 12:33 PM
I don't know if it's feasible to scale this down, but:
Fluidized bed - Wikipedia, the free encyclopedia might have some promise.
fluidized bed combustion,
03/17/2012 12:53 PM
Advanced though it is, this is still a boiler tech though isn't it? Rather than a GT combustor tech I mean.
Edit: I mention this because some of the energy in the fuel is lost through partial oxidation if a gasifier stage 'prepares' the fuel for an I.C. engine (of what ever type).
03/17/2012 1:04 PM
Slowly, are we finding that it may not be an efficient way to burn solid fuel, especially in a small package?
Keep thinking, though. "Rome wasn't built in a vacuum".
OK, it's my day to butcher old sayings.
03/17/2012 1:18 PM
''Polished swords, butter no parsnips''
03/17/2012 1:28 PM
Ooo, sayings! - I got an oldie too: 'Nothing new under the sun'. One that sums up why I'm having a hard time accepting that no prior art exists on this - ie. someone must have had a go at some point.
IIRC there have been times when gas turbines have been used with external combustors, though I can;t recall what difficulty this overcame. I can envisage a part external gasification with the reaction chamber in close proximity to the combustor (heat travels through metal I've heard!). The (mainly) carbon monoxide could then be circulated into the main burner in theory .... except I think the CO would need to be formed with pure O2 otherwise the feed-gas in the main combustor would be aerated with lots of LP air which would ruin any gains from the compressor stage.
03/17/2012 1:30 PM
''the early bird gathers no moss''
03/17/2012 1:41 PM
So true!
03/18/2012 1:33 AM
Lyn my man.
You are what you are.
Do you like Nascar racing?
Re: Solid-Fuel as a Direct (Non-Gasified) Fuel for Gas-Turbines?
03/17/2012 12:30 PM
I do not see a reason why it cannot be done. I suspect that it cannot be done economically or there would be stationary facilities already using pulverized fuel directly into a turbine. I suspect the added pressure boost of enthalpy from converting water into steam and back is the added efficiency why power plants work as tcmtech mentioned. (That's horribly phrased but I think the meaning comes through. Forgive me. )
03/17/2012 12:49 PM
Well, at least I'm not alone in my -crazed- conviction then!In fact I wrote, "I'm sure this must have been experimented with during the age when coal was king" heavily under that influence!
I had reckoned in all the years of using coal there must have been an effort to experiment with, if not gas turbines, then piston engines using the stuff. Perhaps, the very fact that coal is so chemically nasty for high tolerance machinery is why such tests were never bothered with.
03/17/2012 1:25 PM
Rudolph Diesel had coal dust in mind as a fuel when he developed his engine.
Good Answers: 19
03/17/2012 11:18 PM
I was wondering if anyone would mention that bit of history. I believe his difficulty was almost blowing himself to bits? I understand the engine was not strong enough for the coal dust. Or maybe I remember it wrong?
03/17/2012 12:50 PM
Can you explain the bit about pressure boost and enthalpy a bit?
Good Answers: 58
03/17/2012 9:03 PM
An interesting way to burn coal dust is in 'pulsating combustion'. The combustion chamber is shaped like a mason jar, and combustion is very efficient. The Germans experimented with it for power generation, even had some of their rockets using it. We were blowing up their petroleum supplies, so they used coal, very efficiently, too.
mike k
Good Answers: 444
03/17/2012 11:20 PM
OP, you're late to the game, Union Pacific tried direct injection back in the '60s. Read through and you'll see that the coal's abrasiveness lead to the experiment's demise...
"...In October 1961, Union Pacific constructed an experimental GTEL (Gas Turbine Electric Locomotive) of their own, using a modified Alco PA-2 as a cab, the chassis of a GN W-1 class electric locomotive (bought for scrap from the Great Northern) as the second unit, and a modified turbine prime mover removed from one of the 50 to 75 series locomotives. The setup was numbered 80, but changed to 8080 in 1965 to avoid conflict with the new EMD DD35s then being introduced. The consist had an A1A-A1A+2-D+D-2, wheel arrangement, i.e. 18 axles of which 12 were powered[11]. A "centipede" steam locomotive tender was rebuilt with a coal crusher to pulverize and feed the coal to the turbine. Power output was estimated at 7,000 hp (5.2 MW). The original diesel engine in the PA was retained and produced 2,000 hp (1.5 MW) and the turbine produced the additional 5,000 hp (3.7 MW). The blade erosion and soot buildup problems encountered in the earlier locomotives were magnified with the coal turbine. Grinding coal into fine particles was also troublesome. Any oversized coal particles could damage the turbine blades. Ultimately, the experiment was declared a failure and was scrapped. The conventional gas turbines each racked up well over 1,000,000 miles (1,600,000 km) in revenue service, by comparison the coal turbine prototype ran less than 10,000 miles (16,000 km) before being stricken from the UP roster on March 15, 1968. The PA-2 control unit was traded in to EMD, while the turbine unit and tender were scrapped at the Omaha shops..."
Good Answers: 444
03/17/2012 11:37 PM
I forgot to cite Wikepedia for the above info, see the full article here...
http://en.wikipedia.org/wiki/Union_Pacific_GTELs
For a more modern (1981) approach to direct-firing check this out...
http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=1151513
Abstract
A direct coal-fired turbine is a very light engine for powering ships. Weight savings over a diesel engine nearly make up for the added weight associated with fuel bunkering when converting from oil to coal-firing. A method of hot-gas-particulate cleanup based on fragmentation using pulsed CO, lasers is discussed as a means of providing adequate turbine blade life- time. Two cases, a cargo ship and large merchant tanker are considered. Present value of fuel savings equates to the value of a coal- fired turbine For a ten-year lifetime, the value of the turbine due to fuel-lost savings is projected to be roughly 48 M$ for the cargo ship and 194 M$ for the tanker.
03/18/2012 7:38 PM
Thanks RAM' - This is exactly the kind of experimentation that I was convinced some firm or uni/school must've had a go with at some point.
As I wrote earlier, I'll repeat the old adage 'nought new under the sun'. Or put another way, most of everything that technology allows will have been tried - even the borderline ridiculous.
So the lesson I think I've learnt on this is: If you want to drastically shorten the life of your GT then go on and fire it with solid fuel!
03/19/2012 12:19 PM
I've always heard that good engineers don't know everything, they know where to look it up.
I have found, through the years, that the factory service department is the first place to go when looking for answers to problems that you are not already experienced with. They hear about problems with their equipment every day and have the experience to know the most common solutions. I may have one, two, or even ten of these units, they have heard about all the ways hundreds of these same pieces of equipment failed.
The second best source may well be other engineers that you trust. If you ask another engineer with about the same amount of experience as you, you have just doubled the available information. Explaining the problem to a colleague may force you to think about a problem in a different way, bringing up aspects that you may not have even considered.
Both of these sources of help take advantage of the fact that there is just no substitute for experience. Service manuals can be a great source of information, but they tell you how the equipment is supposed to work, not why is doesn't. It is frequently faster to find someone with experience with this piece of equipment failing in this particular way. There is no sense in re-inventing the wheel.
In this case, I would not have thought to use railroads, or locomotives as a search term. Thanks for the info.
It gets interesting when you put fuel and oxygen in the same molecule, without allowing them to react, YET!
03/18/2012 3:31 AM
Modern day wood gas fueled cars....
In the old days....
http://www.lowtechmagazine.com/2010/01/wood-gas-cars.html
03/19/2012 5:11 AM
I know that Rudolf Diesel has made his first trials with the intern combustion engine with dust of coal but one of the great problem was the remaining ashes...
I suppose ashes will also be critical for the erosion of the turbine blates...
Léon LAKAIE
Brussels Belgium
Register to Reply 35 comments
Anonymous Poster (1); lakaie (1); Lapin (1); lyn (3); mike k (1); RAMConsult (2); redfred (1); Ried (1); Sheps (13); SolarEagle (2); tcmtech (1); truth is not a compromise (8)
