Previous in Forum: Data About Chrome Ore (Also Called Chromite)   Next in Forum: Apple iPad or Android Tablet - What Will Be the Industry Standard?
Solar Panel Not Working
03/19/2012 11:52 AM
I have a solar panel on the roof of my RV that keeps my batteries charged, it doesn't seem to be working . Is there a test I can perform to see if the controller is working.
Pathfinder Tags: RV batteries solar solar panel
Re: djkowalik11
03/19/2012 11:55 AM
Measure amps coming off the panel, Boss.
Good moaning!
Re: djkowalik11
03/19/2012 12:12 PM
<sigh>
Was the system working before? Before what (what has changed)? When it was charging satisfactorily, was it then summer and now there is less available sunlight? When it was charging satisfactorily, were you alone using the RV and now your wife and four kids are all using it?
What makes you believe the trouble is the controller?
Re: djkowalik11
03/19/2012 12:33 PM
The unit was working previously, when I hooked up the battery the controller showed it charging but left over night the battery was dead. I put the charger on the battery and the controller showed it chargeing again even with the battery charger on for only a second. I am thinking controller because I read that if the controller was hooked up in reverse polarity there was a chance the controller would get fried.
Trouble With PV Panel In RV
03/19/2012 4:16 PM
Let's break that comment up a little bit, okay?
"The unit was working previously, when I hooked up the battery the controller showed it charging but left over night the battery was dead." Why would you connect the battery to the charger and leave connected overnight? I agree with you, the controller should have stopped discharge of the battery thru the charger... was the battery also connected to the lights/water pump overnight?
I am getting lost in the rest of your comment. Do you believe you may have "... the controller was hooked up in reverse polarity..."?
Good Answers: 73
Re: Solar Panel Not Working
03/20/2012 12:23 PM
Perhaps you are charging dead batteries....After charging during the daylight, remove the charger and check to see how long you still have power. If you only have power for a short while, you probably need to get new batteries.
Good Answers: 58
03/22/2012 5:43 PM
I would hope the controller has a diode to protect it from hooking up the battery backwards. If not, have one installed.
Meanwhile, disconnect the solar panel from the controller and connect a voltmeter to it to see if it is working (during daylight).
If the solar panel is putting out the expected voltage, reconnect it and see if anything is coming out of the controller with the battery disconnected.
Check with the instructions, you may have to disconnect the battery first, to avoid sparks for these tests.
Try an alternate battery, and have your battery tested.
mike k
Register to Reply 6 comments
Crabtree (1); djkowalik11 (1); Doorman (2); mike k (1); NotUrOrdinaryJoe (1)
