Previous in Forum: Calculation of Power for Actuating the Lead Screw   Next in Forum: Hardening Process for Edge of Pencil Sharpener Blade Blanks?
QA Documentation for API650 Tanks
03/19/2012 4:27 PM
I have been asked by one of my clients to compile the QA documentation for equipment that has been installed on their site over the pass 3 years, at the moment these is very little QA packages been supplied by the vendors and contractors.
Please can you advise what is the minimum amount of documentation I should chase up form the suppliers of Auxiliary Boiler Diesel Storage Tank designed to API650.
Thank you.
Re: QA Documentation for API650 Tanks
03/19/2012 7:35 PM
Why would you ask?
It is clearly stated in your OP. The minimum amount of documentation required is, "the QA documentation for equipment that has been installed on their site over the pass 3 years".
That would be any and all QA documentation for equipment that has been installed on their site over the pass 3 years.
It can't be simpler than that.
What the QA documentation for equipment that has been installed on their site over the pass 3 years was required by the original agreements for equipment that has been installed on their site over the past 3 years.
That's all they want.
03/20/2012 4:14 AM
Material specs, heat number etc. Welder qualifications, NDE results, PWHT records, that sort of things.
Good Answers: 25
03/20/2012 6:47 AM
Such documents are prepared before mfg the item. Now how such documents can be prepared?. If it is back dated then it will be invalid.
03/20/2012 10:40 AM
Such documents should have been transferred during commissioning of the equipment.
Poor business practices here.
Register to Reply 4 comments
jmart23 (1); lyn (2); suresh sharma (1)
