Previous in Forum: Ludicrous Software   Next in Forum: Is the inflowing air into the moving car against Bernouli's law?
Electric motor thru bolt (hardware)
05/07/2007 8:38 AM
Need some help here!
I've got an old (25yrs) Minn-Kota trolling motor that needs thru bolts. No service centers carry them anymore, leastwise I haven't been able to find any. Most electric motors have thru bolts to hold them together. Where do the motor makers get them? I'm wanting a 10-32 x 8.5", screw with a washer hex head.
Re: Electric motor thru bolt (hardware)
05/07/2007 11:30 AM
Make one. Go to the hardware store and buy threaded rod, nuts and washers. 5 min. job and you've got bolts. For the head, jam one nut against another nut.
05/07/2007 11:25 PM
That's pretty much what I was going to say, but I'll add:
1. Since it's for marine use, spring the extra bucks for stainless steel.
2. On one end put a couple of nuts so you can hold it in a vice without damaging the threads. Leave a couple mm (0.1") of rod sticking up past the upper nut, and peen the end over. Now back the nut closest to the peen 'till it hits the peened end and you've got a very reliable head. Use a hand drill to rotate the rod to remove the other nut.
05/08/2007 12:40 AM
Go to the hardware store and buy some 10-32 all thread rod get nuts and washers to your liking and make your own bolts,with a nut and washer on each end.
05/08/2007 2:57 AM
Just weld the nut to the rod after you got the right langht
05/08/2007 8:20 AM
try Mc master Carr...www.Mcmaster.com they will most likely have what you are looking for
God's greatest gift is the ability to learn.... and the worst curse is the ability to rationalize our behaviour
05/08/2007 8:43 AM
Best they can do is 10" then you'll have to cut it off, but as stated don't use in Marine.
99117A570
Extra-Long Pan Head Combo Drive Machine Screw 10-24 Thread, #2 Drive, 10" Length
Live Slow - Sail Fast
05/10/2007 11:19 AM
OK. I see I'm not the only person in CR-4 with a degree in Af*!(@n Engineering!
What I'm looking for is a source for screws of the desired configuration. Somebody makes them and motor manufacturers use them. Where does one get them?
McMaster-Carr, do not have what I need (except stainless all-thread), and I don't want to use the all-thread.
Pull out the stops, Guys!
Register to Reply 7 comments
CaptnPea (1); dkwarner (1); dovrak (1); drdave (1); duffdr (1); hilltopper (1); Labyguy (1)
You might be interested in: Bolts, Motor Test Equipment, Motor Repair Services
