Previous in Forum: Nuclear Heat   Next in Forum: Arc Suppression
10 comments
CONTACTOR
03/23/2012 2:37 PM
REASONS FOR CONTACTOR COIL BURN OUT?
Anonymous Poster #2
Re: CONTACTOR
03/23/2012 2:43 PM
See google search...
Good Answers: 131
Re: CONTACTOR
03/23/2012 2:50 PM
Probably too many hours working, with too little sleep.
(And stop SHOUTing!)
Good Answers: 58
Re: CONTACTOR
03/23/2012 3:36 PM
Perhaps a LOT of stress also!
Good Answers: 181
Re: CONTACTOR
03/23/2012 6:47 PM
It got fed up of you SHOUTING and committed suicide!
Good Answers: 804
Re: CONTACTOR
03/23/2012 7:36 PM
Too much...
Voltage, current, useage (duty cycle), heat, moisture, dust, particles between the pole faces of the armature, bugs nesting in same...
Too little...
Voltage, current, routine maintenance such as blowing out the dust, bugs, moisture etc. from the above...
Bad...
Design, installation, wiring, environment, luck...
Good Answers: 15
Re: CONTACTOR
03/24/2012 12:24 AM
spurious coil not from original manufacturer? poor voltage waveform in case of AC coil?
Good Answers: 50
Re: CONTACTOR
03/24/2012 6:47 AM
Heat??
Something new every day!
Good Answers: 58
Re: CONTACTOR
03/24/2012 12:51 PM
Check the coil for the required voltage. The instructions on the box cover will show how to connect the different voltage coils.
mike k
Re: CONTACTOR
03/25/2012 11:40 PM
Check whether the contactor rating is selected for continous (i.e as per type-2 coordination) operation.
This will be the major cause for contactor failure. And obviously the failure will be due to over heating of coil during continous operation.
"Learning new things everyday keeps u healthy"
Re: CONTACTOR
05/15/2012 6:12 AM
the reason of burning the contactor coil is, maybe the person who install is not qualified electrician he did not check if the contactor voltage is 24dcv or maybe the voltage on the contactor is 240acv he connect to 120acv !!!!! warning before connecting your machine or any electrical parst with a coil first check the voltage and second call the qualified electrician !!!!
i want ot helf piple need assistance and to share my knowleged in technical
Anonymous Poster (1); JRaef (1); KJK/USA (1); MalcolmK (1); mike k (1); PeterT (1); soebfatehi (1); toink (1); TonyS (1); yooogs (1)
