Previous in Forum: Is the inflowing air into the moving car against Bernouli's law?   Next in Forum: Crude Oil Pricing vs Ethanol Cost to produce.
Lower flex coupler for steering column
05/07/2007 12:39 PM
I have a 1998 Toyota Avalon - we are trading it in within 4 weeks.
All of a sudden the steering wheel will hardly move. Should we fix or not?
An estimate of $400.00 to fix this problerm. How do you feel about this Price.
I was trying to get an estimate on the part to make sure this is what I should expect.
Mary
United States - Member - USA Engineering Fields - Control Engineering - Never enough money
Re: lower flex coupler for steering column
05/07/2007 1:19 PM
Your trade-in value is around $5,000-$6,000 USD if your car is in fair condition and if you live in the U.S.
It would most likely be in your best interest to have it fixed for the $400 USD. But before you spend the money check your belts and fluid levels. If your power streering belt broke this could cause your problem and can be fixed for $20 or your power steering fluid could be low, this would be a $5 fix by adding fluid. If you are not sure what you are looking for ask a mechanically inclined friend for help.
Kelly Blue Book defines "Fair" condition as: "Fair" condition means that the vehicle has some mechanical or cosmetic defects and needs servicing but is still in reasonable running condition. This vehicle has a clean title history, the paint, body and/or interior need work performed by a professional. The tires may need to be replaced. There may be some repairable rust damage.
05/07/2007 1:23 PM
If the steering wheel does hardly move, it means that the hydraulic steering system has no more fluid in it. If the only problem is the lower flex coupler, I would have it repaired... but not for 400 bucks!
Good Answers: 247
Re: Lower flex coupler for steering column
05/07/2007 7:17 PM
Definitely fix it. Whoever you trade it to will have to deduct more than the repair cost for risk. But get a second and third diagnosis and estimate: $400 seems expensive.
Blink (1); r&ddoc (1); Richard L (1)
