We need to cool some very temperature sensative electronics to 23C +/- 0.1C. The total heat load is about 350watts and should be very constant in time. The only heat that varies is that coming in through the walls of the enclosure and that shouldn't change very fast, because the machine itself is in a controled environment.
The electinics will be cooled by a closed loop forced air circuit, but we then need to get the heat out of the air. I would like to test a refrigeration loop using a variable speed Aspen compressor, but there is doubt about whether the Aspen compressor can control the air temperature well enough. Has anyone used one of these variable speed compressors to precisely control air temperature? It seems to me that a PID with a strong itegral factor and a weak derivative factor should keep it constant and prevent dithering, but that is all theoretical. I really need to know if anyone has succesfully used the compressor for something similar.
