Previous in Forum: Machine Drive Chain   Next in Forum: Lube Oil Pipe Material in ST Should Go By SUS or Can Go By Carbon Steel?
8 comments
Pressure Rating for a Custom Forged TEE
03/29/2012 5:55 PM
I need to model a 2" forged custom TEE made out of 4130 Steel (heat treated to 100000 psi yield) to be used as a pressure relief valve body at 12000 psi.
What code/formula do I use to get the minimum required thickness of the TEE to withstand that pressure?
Thanks!
Alok
Re: Pressure rating for a custom forged TEE
03/29/2012 7:51 PM
What's the specification say?
Good Answers: 11
Re: Pressure Rating for a Custom Forged TEE
03/30/2012 10:57 AM
Well I'm not sure which code you want to use but in the case of ASME B31.3, you can either make it and test it exactly like they suggest in their various codes OR...
302.2.3 Unlisted Components
(a)
Components not listed in Table 326.1, but which
conform to a published specification or standard, may
be used within the following limitations.
(1)
The designer shall be satisfied that composition,
mechanical properties, method of manufacture, and
quality control are comparable to the corresponding
characteristics of listed components.
(2)
Pressure design shall be verified in accordance
with para. 304.
(b)
Other unlisted components shall be qualified for
pressure design as required by para. 304.7.2.
I would check out Para. 304.7.2 in the code. My understanding of what you're doing is that you are custom building a fitting that may not match anything listed. You have options on how to verify it but it sounds like you might need an FEA analysis.
Also, I would read the scope of ASME B31.3. It's a common standard but what you're doing may or may not be covered under this standard.
Out of curiosity, why do you need a custom built Tee?
03/30/2012 4:35 PM
Thanks for your response Cingold.
I need the TEE to be rated for 12000 psi, which will be a lot thicker than any of the standard 2" TEEs. Also, my face to face dimensional requirements are different than a regular 2" TEE. Because of such a high pressure rating requirement, I am looking to make it out of 4130 forging, heat treated to 100000 psi yield strength.
Thanks!
Alok
04/01/2012 2:00 AM
If the problem is yp VERSUS REQUIRED Thickness
Why not to use:43400 or European nearest Equivalent;34NiCrMo6 ?!?
(YP=1320-1080 MPa,compared to your 100 KSI-equivalent to 681 MPa)
Good Answers: 11
04/02/2012 8:58 AM
Without knowing all the details of your project, I think you would need FEA for this, especially at this pressure. Check out the high pressure section of B31.3 as well (some details on it are listed below).
03/31/2012 2:35 AM
● See ASME BPVC, Section VIII-3, Para. KG-100 Scope.
KG-101 Intent. The rules of this Division constitute requirements for the design, construction, inspection, and overpressure protection of metallic pressure vessels with design pressures generally above 10 ksi (70 MPa). However, it is not the intent of this Division to establish maximum pressure limits for either Section VIII, Division 1 or 2, nor minimum pressure limits for this Division. Specific pressure limitations for vessels constructed to the rules of this Division may be imposed elsewhere in this Division for various types of fabrication.
● See ASME B31.3, Chapter IX "High Pressure Piping", Para. K300 General Statements.
(a) Applicability. This Chapter pertains to piping designated by the owner as being in High Pressure Fluid Service. Its requirements are to be applied in full to piping so designated. High pressure is considered herein to be pressure in excess of that allowed by the ASME B16.5 Class 2500 rating for the specified design temperature and material group. However, there are no specified pressure limitations for the application of these rules.
03/31/2012 8:46 AM
It seems that the automatic OT marker software has run amok.
I don't know how this answer is OT.
04/01/2012 7:49 AM
Why not you consult some safety valve manufacturer to guide you?
Register to Reply 8 comments
Abdel Halim Galala (1); alokd (1); cingold (2); Jacob Klepatch (1); lyn (2); Mukesh0861 (1)
