Previous in Forum: [Excel] Moving Data from Rows to Columns   Next in Forum: Cruzer Zip Drive Quit Working
Memory Information
03/30/2012 4:39 AM
please learn me the detail of Virtual memory And Page file in windows. also what is the different between page file and virtual memory. what is the purpose of these memory.
thank you.
"Keep work and family separate. "
Pathfinder Tags: memory information
Re: memory information
03/30/2012 5:47 AM
Good Answers: 73
Re: Memory Information
04/04/2012 10:53 AM
Your brain may hurt after you read all of those link above. Virtual memory is where data is stored on some other device, as in a file on the hard drive. It simply refers to information you may not be able to retain in random access memory because there is not enough room.
Memory is a confusing term because there is more than one type. The memory that your computer or processor uses to do its basic functions (so that you can do other things, like type on the keyboard or display information) is your operating system at the system level. This memory is permanent and can not be erased.
Then you have some "firmware" memory which keeps data even when the power is turned off. Finally, you have RAM or random access memory which consists of programs and data that you use as an operator. All of this memory is organized by locations which tends to be in groups called pages. That term may be processor dependent or system dependent as in 16 bit wide data, 32 bit wide, or 64 bit wide.
Each system has a different page length, depending on the ability of the addressing hardware to access it. Some areas are reserved but most is available for your use.
Sometimes when computers "lock up" it is because one program overwrote memory that another program was using. That causes programs to become hopelessly lost.
Hope that helped!
04/06/2012 9:59 AM
Virtual is what your computer uses when it starts up to run programs Page file extends the Virtual memory any other help call CR4 Admin - email address and phone number removed From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
Register to Reply 3 comments
NotUrOrdinaryJoe (1); saveone12 (1); SolarEagle (1)
