Previous in Forum: Thermocouple Class and Error   Next in Forum: MSystem
15 comments
Twisted Pair Thermocouples Principle
04/03/2012 3:39 PM
Does anyone know what principle is behind thermocouple that has its leads twisted?
If this is to cancel the induced voltages from E/M stray fluxes, then must not the dys-similar wires must be magnetically identical? So, why Chromel-Alumel TCs have twisted leads? What is achieved by that?
Thank you
User-tagged by 1 user
India - Member - New Member
Good Answers: 164
Re: Twisted Pair Thermocouples Principle
04/03/2012 11:17 PM
As you say, twisting is to eliminate noise. Maybe you will get some useful info from this paper...
http://www.acromag.com/sites/default/files/Basics_of_Temperature_Measurement_Using_Thermocouples_911A.pdf
04/04/2012 5:31 PM
Shreedhar.
My specific question was the following: how twisting the magnetically dissimilar wires such as Chromel (non magnetic) - Alumel (magnetic) achieves an E/mag field (we use it inside the electric machine) interference noise cancellation?
Can you advise? My view, that is does not.
Good Answers: 164
04/04/2012 9:46 PM
Frankly, i have no firsthand experience in this, except to the extent of telling my lab technician to twist the ends. As per this part of the document whose link i gave...
Good Answers: 164
04/05/2012 4:11 AM
i am perplexed. This was a GA a few hours ago. Someone has then voted it OT, cancelling one vote. Why? My post gives a link to an excellent paper. Is that paper wrong? Useless? So why did you vote OT my friend? Not that i am bothered with GAs, OTs......whatever. Just curious about how some minds work....
04/05/2012 5:17 AM
The paper is excellent and it can give wide information about thermocouples.
But it never answered the question. Here the question is how can different material can produce magnetic field having same magnitude to cancel each other due to the same current flow (May or may not be question logical).
Since the explanation is not an answer for the question, your post is OFF TOPIC.
Good Answers: 164
04/05/2012 7:52 AM
Ah....that seems reasonable. You did not have to hide behind anonymity while posting this. (You are a registered user, since you voted. APs can't) Please note that i never claimed personal knowledge about the phantom problem posed by the OP (Are you the OP?) i merely highlighted that twisting eliminates noise, as per some expert. So .... stands to reason that despite being different materials, electromagnetic field are induced (as mentioned by another poster)....what other noise can be there?
Up to you what you want to believe.
Anyway, i will not respond in this vein again, and will only seek new knowledge as may appear by good posters.....
04/04/2012 6:07 AM
Twisted shielded pair has very good immunity to noise pickup. Think of an untwisted pair as a loop of wire that behaves as a single turn transformer secondary winding. Twisting it causes cancellation of the magnetic pickup. The grounded outer shield keeps out electrical fields. The shield should be grounded at one end only to prevent ground currents.
04/04/2012 5:32 PM
Rixter.
Alex
Good Answers: 176
04/04/2012 9:52 PM
I think you're confusing a 'magnetic' conductor with the 'magnetic' field that induces a voltage, which would be noise to a thermocouple.
The concept is Faraday's law - a voltage/current will be induced in a stationary (closed circuit) conductor that bounded by a moving magnetic field.
The conductor need not be magnetic for this to happen. Copper is not magnetic but a copper winding certainly carries an inducec current from the magnetic flux of an adjacent transformer winding.
Both thermocouple metals qualify as conductors, and warrant twisting so that the currents induced by flux passing between the wires in each twist is cancelled by that in the next twist.
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
04/05/2012 3:19 AM
Here both conductors are the part of the same loop and the current flow is same through both conductor. So it doesn't matter what the material is.
Magnetic field is directly proportional to the current flow. So will get cancelled each other.
If you can't find a way, make one........
04/10/2012 2:06 PM
Justin.
Good answer, but.. thermocouples are open-ended at cold junction. So, if both ends were connected, hot and cold the common current would flow through the circuit. However, the cold end is open, usually connected to the high impedance measurement device. So why bother twisting the wires?
Alex
04/05/2012 10:25 AM
Effective magnetic field around both the wires running side by side [of the same circuit] has nominally zero; normal 2 wire cable.
But if those twisted it bwill ecomes better cancelliom and used in Tests and Measurements.
Remember that Clamp-on Current meter only reads if clamped around a single wire.
If clamped around both the wires it will read zero.
For your intrest probes are made to measure current by inserting it between the wires.
It will read double the current?
Try to understand by drawing field around and inside of 2 wires.
04/10/2012 2:08 PM
Haajee. A thermocouple is open at cold end, connected to the High Impedance reading device. So there is no current flowing. If you know different, please explain.
Thank you
Alex
04/11/2012 8:34 AM
Yes it is open if not in use.
When connected in system it is loaded no matter how high the impedance is.
Simple example is in natural/ petrolium gas [As 'gas' may not be mixed with 'gas'
spoken for petrol in US] Flame sensing is through a thermocoule which drives and holds the Gas-Valve if the flame is there. as soon as flame extinguishes the Gas-Valve is shut.
Before starting the flame Gas-valve is kept open manually with a button, held for some time to work the thermostat.
There is difference between Thermocouple and a thermal switch.
04/04/2012 7:26 AM
Sorry.
There is no such Thermocouple System but there are cables for thermocouples of this description which has certain advantages in measurement. Not only in temperature but all electrical and electronic measurements.
like:
Temperature Sensors
Testing / Laboratories ie professional testing
New Plant Construction -Warrantee
General Industry (mills, refractories, etc) -Troubleshooting
Twisted shielded pair allows for a tighter bend radius, reduced crosstalk and reduction of EMI
And one advise:
Please do not put Answers @ Yahoo in CR4 discussions.
and try to search to learn and impart what you know or have in your stock.
Never hesitate to question hide what you know.
I am subscriber to yahoo answer and get such questions which may not be properly put.
Have fine time to learn and impart. Good luck!
Register to Reply 15 comments
Alexgeps (4); Anonymous Poster (1); Haajee (3); Iris (1); justinanto1987 (1); kvsridhar (4); Rixter (1)
