Previous in Forum: Tan Delta   Next in Forum: Tan Delta
220 kV Distance Protection
04/08/2012 9:25 AM
pls give me an ans of calculation of Distance protection of line..like ZONE-1 ,2,3,4 ? & it's value in OHM so, during tripping how it is calculate the R ?
Thanking you in advance.
Re: 220 kv distance protection
04/08/2012 11:15 AM
04/08/2012 12:28 PM
Good Answers: 131
Re: 220 kV Distance Protection
04/09/2012 2:07 PM
Another place you can do some studying to understand impedance (line distance) relaying is (free download PDF):
http://www.gedigitalenergy.com/multilin/notes/artsci/index.htm
04/10/2012 2:19 AM
Backup To Busbar ProtectionWith
Numerical Distance Protection
Shashank Jewalikar; Dy.E.E, MSETCL
email id: shashank.jewalikar@gmail.com
TPF
FPT
Abstract
- An application idea for applying distance
protection to backup the busbar protection is presented
here. The proposed scheme is applicable to substations
with following bus configurations.
1) 2 Main + 1 transfer bus with bus coupler.
2) 1 Main + 1 Transfer bus with bus sectionalizer breaker
3) 1 Main bus with sectionalizer breaker.
The proposed scheme envisages use of reverse zone of
existing numerical distance protection relays in a different
way than conventionally used in utilities.
Index Terms
- Busbar protection, Numerical distance
protection, backup to busbar protection, reverse zone
I. INTRODUCTION
A bus differential protection is applied for protection
of busbar against bus faults. Looking at the various reports of
past occurrences in our network; there are many occurrences
involving non operation of bus bar protection schemes. Any
case of such non operation,
1. Always results into loss of complete bus as no selective
tripping are possible in present scheme.
2. Delays the fault clearance as the fault in such cases will be
cleared by remote Zone 2, Zone 3, T/F or generator backup
protections as the case may be.
3. Increases the spread of occurrence.
4. Many times results into a wide spread system disturbance.
This can lead to a cascade tripping condition.
Practices for enhancing reliability of Busbar protection:
For enhancing the reliability of busbar protection; following
practices are adopted.
1. Main and check zones in busbar protection.
ar protection schemes in 1 out of 2
erse zone is also said to act as a back
ication
1. T
zone
3. T opted in these cases is generally more
4. T
ackup to remote Zone 3 for the
e
ng bus
vided in two sections
3. 1 Mai
Author is working as Deputy Executive Engineer (Testing) at 400 kV
Girwali substation of MSETCL .
2. Replicated DR with check zone in RADSS
3. Main 1 and Main2 busb
or 2 out of two trip logic.
4. Distance protection rev
up for busbar protection.
First three of these practices are basically busbar repl
schemes with same differential operating principle.
Present practice for reverse Zone as back up to busbar:
he reverse zone of numerical line distance protection is
adopted to cover the bus at many places. The reverse
is generally set to cover 10% of the line impedance.
2. This is said to be a back up to the busbar protection.
he time setting ad
than Zone 3 time.
his makes the operating possibility of reverse zone
virtually remote. The bus fault; in case of non operation of
busbar protection is cleared from remote end Z2 & Z3 as
the case may be. The purpose of reverse zone backing up
bus bar protection is defeated. In a way the reverse zone in
this case is acting as a b
local bus coverage area.
The gravity of this situation can be reduced to a large extent
if bus coupler / bus sectionalizer breaker can be opened before
any Zone 2 operation takes place. This can be achieved by us
of reverse zone available with numerical distance protection
relays. The necessary configuration & settings are discussed
here. The sugges
Zone 2 Trip Zone 2 Trip
Reverse zone of
line
T > T Zone 3
ted scheme is applicable to followi
configurations.
1. 2 Main + 1 Aux. bus with bus coupler breaker.
2. 1 Main + 1 Aux. bus with Main bus di
By way of opening the bus coupler before any Zone
2 operation; the bus fault will be limited the faulty bus section.
This fault will be eventually cleared by the remote Zone 2
Fig 1: Non operation of busbar protection.
FAULT
Fig 2: Present practice of Z3 usage
Fifteenth National Power Systems Conference (NPSC), IIT Bombay, December 2008
403
protections of the lines; transformer / generator backup
protections connected to that bus section only. (Ref. Fig 3)
Requirements of the scheme:
1. Time:
1. Bus coupler breaker should open before any remote Zone 2
operation.
2. Bus coupler trip should not be initiated before Zone 1 fault
clearance time.
3. The bus coupler trip should not initiate the LBB (50Z) of
d by the distance protection from which the
onnected to the bus.
4. A 20% of shortest line impedance can be used for
ments a two stage configuration of
Tw
2. T
fixed impedance so as to
l
e
nce
g
e zone start continued. (Refer figure 4
00 kV lines as discussed
trip the
se Zone Stage 1 ---------- Trip Bus coupler.
section only. If any of the remote lines
fa
ulty bus section
stead of
up protection operation.
A logical representation of the scheme is shown in
line protecte
bus coupler trip is obtained.
2. Impedance:
1. The reverse zone always must cover the local bus
completely.
2. The reverse zone should never encroach into Zone 2 of any
of the lines c
3. The reverse zone can be set to cover 10% of protected line
impedance.
setting of
all lines where a short and a long line are connected to the
same bus.
Considering these require
reverse zone is suggested.
o stage reverse zone
1. Numerical distance relays are having separately settable
impedance zones for reach as well as direction.
he reverse zone impedance to be set to cover the bus fault.
The impedance setting to be adopted as per the
requirements discussed above. A
cover the bus can also be thought over in this case for al
the lines c
3. A two stage trip is to be obtained from this reverse zon
element
4. Stage 1: The reverse zone stage 1 will be obtained as
below.
The reverse zone start signal will be used to start an internal
timer. The timer will be set to less than Zone2 time setting of
remote end protections and more than Zone1 fault cleara
time of local end. Considering currently adopted time settin
on 400 kV level (T Z2 =300 mS & T Z1 =0 so Z1 fault
clearance = 100 mS), a time of 200 mS can be set for the
timer. An output contact will pick up on operation of timer
with presence of revers
& 5) This output contact will be used to trip bus coupler /
Stage 2:
The stage 2 will be from the operation of the reverse
zone element set to a time delay of more than zone2 time.
Zone 2 Trip
With currently adopted timings for 4
above; it can be set to 400 mS. This will be used to Reverse zone of
line own breaker of the protected line.
Rever
T = 200 mS
Reverse Zone Stage 2 ---------- Trip line breaker of protected
line.
T
he stage 1 will trip the bus coupler breaker and isolate the
faulty section. The fault will now be cleared by the remote end
distance protections in Zone 2 or the T/F and generators
connected to the faulty
Zone 2 Trip
ils to trip till the stage 2 operation; stage 2 will trip the line
breakers at local end.
If the fault remains till the time of stage 2 operation a
thought can be given to initiate tripping of fa
totally(i.e. along with transformers and generators) in
waiting for their back
following diagram.
The reverse zone stage1 operation logic is like creating a
new zone of operation inside the relay.
Logic Verification & testing:
The suggested scheme logic is verified on Micom P442
relay (ref fig.6). The logic testing was carried by using the
automatic relay testing kit Omicron CMC 256-6. The method
Figure 3: Reverse zone suggested usage
Timer
(200 mS)
Reverse Zone Start
AND
LOGIC
Reverse Zone
Stage 1 trip
Reverse Zone Trip (T=400mS) Reverse Zone Stage 2 trip
Figure 4: Reverse zone 2 stage operation logic.
OR
LOGIC
Any forward zone trip Trip protected line
breaker
Start LBB of
protected line
Reverse Zone Stage 1 trip Trip bus coupler
breaker
Start LBB of Bus
Coupler
Figure 5: Reverse zone 2 stage trip logic
404
included applying faults through the kit and replaying of
actual fault records. The relay was set to real line settings of
one of the lines in the MSETCL 400 kV network.
DDB #195
Z4 Pick-Up
200
0
DDB #195
Z4 & Pick-Up
0
0
Relay Label 08
DDB #007
Rev Zone Start Trip Bus Coupler
Rev Zone Start Timer T=200mS
sent protection
(M provided on all lines.
F o
1. B
and stage 2 tripping can be
at the reverse zone stage 1 trip should not
i
ections can be used for a two stage
stance protection:
tion will be used for two stage
r
3. Su 00 kV
o 1 S
zone stage1 operating time. As
the V lines is 400 mS, the
stag be taken to 300 mS for tripping
of bu
1 or 220 kV
ne 1 fault in 30% of line section the fault
tion in service should
e
onfigured in the relay to achieve the same functional
below.
am (Fig.4
& 5
reve
1. N e 1 & Reverse Zone = Stage 2
& 5) and
recommended
2. N tage 1
In
a
b
re internal LBB is
dition.
ed to the general
3. R
a cility for creation
b
or external LBB of the feeder. The necessary care
4. R
S
possible to configure the reverse
b
cable here.
the general
The possibility of having similar configuration with REL
521 relay is also verified.
Implementation:
The possibilities of configuration and
checks required are discussed in view of pre
practice of 400 kV & 220 kV lines.
Case 1: 400 kV Substation where two distance protections
ain1 & Main2) are
oll wing situations are considered for this case.
oth numerical protections on line: Following possibilities
exists in this case.
a. The reverse zone stage 1
separately obtained from each of the relays. It is essential
in this case th
in tiate the LBB protection.
b. Only one of the prot
reverse zone.
c. A series combination of stage1 reverse zone from both
is also possible
2. One numerical and one static di
a. Only numerical protec
everse zone.
ggested timings for 4
a. Present Zone timings
i. Zone1 = 0 mS
ii. Zone 2= 300 mS
iii. Zone 3 = 500 mS t
b. Reverse Zone timings suggested
i. Stage 1 = 200 mS
ii. Stage 2 = 400 mS
Case2: 220 kV substations where the main protection is
distance and back up is IDMT O/C & E/F
In such condition the scheme can be applied safely as far as
all of the distance protection relays connected to the
concerned bus is in service and functioning correctly.
The scheme can also be safely applied when the Zone1 fault
clearance time on the overlapping area of reverse zones and
Zone1 with only back up protection operation can be
coordinated with the reverse
Zone 2 operating time for 220 k
e 1 reverse Zone time can
s couplers in this case.
. Suggested timings f
i. Zone1 = 0 mS
ii. Zone 2= 400 mS
iii. Zone 3 = 700 mS to 1 S
i. Stage 1 = 250/300 mS
ii. Stage 2 = 500/600 mS
Check:
For a Zo
clearance time with only back up protec
b less than the stage1 trip time of reverse zone used to trip
the bus coupler.
Configuration possibilities and LBB:
The numerical relays are providing lot of flexibility for
their configuration. Different logical formations can be
possibly c
behavior. The functional behavior of the numerical relays is
always a combination of its logic configuration and settings
adopted.
Some possibilities while configuring & setting the relay for
adoption of this busbar backup scheme are discussed
In this the logical formation shown in the logic diagr
) above to initiate the stage 1 is referred as 'new zone' and
rse zone of the relay is referred as 'reverse zone'.
ew Zone = Stag
a. This is as shown in the logic diagram (Fig.4
described already. This is the
configuration.
ew Zone = Stage 2 & Reverse Zone = S
this case following precautions are essential.
. The stage 1 trip needs to be disconnected from all
general trip conditions inside the relay.
. The stage 1 trip should not initiate the internal or
external LBB of the feeder. The external LBB initiation
can be avoided in wiring. In cases whe
used; a configuration change becomes essential. A check
should be made with the relay logic for possibility of
separation of such initiation con
c. The stage 2 here needs to be connect
trip conditions initiated from the relay. The stage2 will
initiate the LBB of the feeder.
everse Zone = Stage 1 and No stage 2
. If any of the relay is not providing fa
of new zones this configuration can be used.
c. Here also the stage 1 trip should not initiate the
internal
as discussed in 2 above is applicable here.
ev Zone of Main1 = Stage 1 and Rev Zone of Main2 =
tage 2
a. When both main1 and main2 both numerical distance
relays are provided; it is
zones of one for stage1 and the other for stage2.
. The stage1 trip needs to be disconnected from all
general trip conditions.
internal or external LBB of the feeder. The necessary care
d. The stage 2 here needs to be connected to
Figure 6: Reverse Zone stage 1 logic as implemented
in Micom P442
405
5. U
tage2 comes up. This may not
guration becomes possible; the zone
eparated from the general trip conditions.
T
con
ic and timing modifications.
time check zone in combination with distance
ves
rotection
reverse zone to trip the bus coupler / sectionalizer breaker will
serve this purpose and limit th the disturbance.
r
t
se of multiple reverse zones from one relay.
a. Some of the numerical relays are providing facility to
have more than one reverse zone from one relay.
b. In such cases a possibility of configuring one for
be used unless it is possible to configure the relay for
continued measurement by other zones even after tripping
is issued by one of them.
c. If such confi
configured for stage1 should never initiate LBB of feeder
and be s
Extending the idea:
he idea can be extended. Following variations can be
sidered.
1) The scheme can be used to isolate the auxiliary bus faults
(i.e. by tripping the TBC breaker only) before stage2 trip
by some log
2) A definite
reverse zone can be considered for increasing the stability
of scheme.
Conclusion:
Non operation of busbar protection always increases the
spread of the disturbance. Applying relaying with different
operating principle to backup the busbar protection will be a
good practice. The present practice of utilizing reverse zone
with operating time more than Zone3 as busbar backup ser
no purpose. The suggested usage of distance p
e spread of
Shashank Jewalika
400 kV Testing Uni
MSETCL
Girwali -431 519
Ref
1. Micom P442 technical manual.
2. REL 521 technical manual.
3. Protection relay application guide- AREVA
erences:
406
Curiosity made genius
Register to Reply 4 comments
lyn (1); nobodysomebody47 (1); PeterT (1); yk (1)
