Previous in Forum: How To Measure The Flow Of Water From A Peristaltic Pump?   Next in Forum: On-Site Flange Facing Machine
PVElite Problem-Cone-External Pressure Thickness
04/12/2012 9:08 AM
Dear All and Moderators,
I am using PVElite 2011 built 13.0.0.0
I am modelling a vessel having a cone at bottom, shell at middle and torispherical dish at the top.
the vessel is under external pressure of 1.0341 bar (Full vacuum)
Large and small end of cone are not considered as lines of support.
only Large end of the cone is provided with a knuckle radius as per ASME section VIII Div:01.
I am providing a stiffener on shell.
Also I am providing a stiffener on cone at the mid length.
When I see the results for external pressur calculation, Pvelite calculates correctly length between 2 stiffeners as the deciding factor for thk calculation for shell and for bottom cone.
After closing the results, when I return to the main screen (Interface), On bottom right corner, where we see required thickness for pressure parts, the values dont match with the results in result file.
Also as per code it is allowed to use stiffeners on cone (Fig:UG-33)
Moderators please help.
Regards
ASD23789
The light of blindness of knowledge is yet to reach me, forget being clever.
Good Answers: 38
Re: PVElite Problem-Cone-External Pressure Thickness
04/13/2012 9:40 AM
PVElite is a superb and complex piece of software that was developed in the USA after the investment of millions of dollars or research money and many, many years of hard work.
Currently, many more pressure vessels are being designed and fabricated in India than ever before. In the USA, this industry is in decline and many people cannot find jobs. These are the same people who developed this superb tool.
Banu, it is always difficult getting technical assistance and guidance on software that is stolen. This type of question you posed is usually answered directly by the vendors because he wishes to help his paying customers....
04/15/2012 8:36 PM
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Good Answers: 67
04/16/2012 12:38 AM
"vessel is under external pressure of 1.0341 bar (Full vacuum)"
Is the outside the vessel is at atmospheric pressure? If yes, then for full vacuum external pressuressure will be 1.01325 bar only.
Good Answers: 11
04/22/2012 10:03 PM
"1.01325 bar only" (at sea level). Maybe a typo or not at sea level.
Register to Reply 4 comments
jackchen (1); Malcolm Stephen (1); MJCronin (1); pritam (1)
