Previous in Forum: Nuclear Wave Reactor   Next in Forum: AC-Stuck Rings
10 comments
High Pressure Solenoid Valves
04/13/2012 12:10 PM
I have been searching for solenoid valves 3/8 tubing, 110 volt. max PSI 1000 with a max cycle time of 20 per minute. Product is CO2. Temp range would be from -20 to 100 C, I have found several in my searches but am having difficulty getting company to correspond. Would any of our esteemed contributors have some suggestions as to a reasonably priced solenoid valve suitable for the mentioned parameters. I will need about 16 to start for the prototype device.
Good Answers: 125
Re: High Pressure Solenoid Valves
04/13/2012 12:55 PM
100 C ????
At 31 C Carbon Dioxide hits critical temperature where the liguid and gas portion have the same density, and the liquid phase disappears. At 100 C the pressure of CO2 is around 10,000 PSI, and your 1,000 PSI valve is history.
04/13/2012 1:54 PM
The critical point is a temperature and pressure and pressure point in any phase diagram, not a line or curve. However 73 atm calculates to 1,073 psi so the OP is asking for an irrational pressure level just below this pressure. I doubt that the pressure regulation accuracy will be sufficient to prevent a supercritical fluid from forming.
Phase diagram from http://www.teamonslaught.fsnet.co.uk/co2_info.htm
I suspect that this state uncertainty is why vendors may not specify a valve to operate at this level.
I do not understand though why a supercritical fluid originally at 31°C (304K) if heated to 100°C (373K) would now increase by an order of magnitude in pressure. This is not an order of magnitude in absolute temperature change and with the density no longer possible to change I only see a modest increase in pressure. However, I have never worked with supercritical fluids nor have I found an easy to find web search that explains what the pressure change of supercritical fluid will be when temperature changes. I doubt that the universal gas law applies now. Could you provide a link that can help clarify the pressure change.
Good Answers: 125
04/13/2012 2:30 PM
I work with CO2 systems on a daily basis. When we are not controlling the CO2 using refrigeration, we store it in bottles that have 2 pounds of steel for every one pound of agent stored.
CO2 has a triple point as well, where all three stated can exist at the same time; a rather interesting fact.
Good Answers: 125
04/13/2012 3:03 PM
I have researched and like you cannot find a chart for this. I know that my 2400 PSI reliefs will pop at 54 C. The highest temp/press in print I can find is 3500 PSI at 65 C. The 10,000 PSI at 100 C is a figure my cylinder manufacturer brandishes.
As I understand it, above the critical pressure, the pressure is difficult to model. Some use the Soave Redlich Kwong equations. I guess that is why charts are not available.
04/13/2012 3:02 PM
04/13/2012 4:34 PM
You can do a search on GlobalSpec©....
04/13/2012 6:23 PM
Thank you for that info and to all my other friends I am not into a refrigeration project so most of those numbers do not apply. I just need a source on solenoid valves as specified.. Thanks again.. great discussion but a bit off track re the valves.. Cheers
04/13/2012 6:45 PM
Did you try searching Global Spec?
04/13/2012 7:03 PM
Just did as Solar Eagle advised and have requested a quote..It is a great site and appreciate the leads and info.thanks again.
04/16/2012 10:31 AM
Well, as roy has identified redfred and solareagle collectively as a Good Answer, I will vote accordingly... I guess...
As I consider, GA to WJMfire as well. Sort of like corn on the cob: Good input, but not completely absorbed.
Register to Reply 10 comments
Doorman (1); redfred (2); roy hammy (2); SolarEagle (2); WJMFIRE (3)
