Previous in Forum: Synchronize old IBM clock   Next in Forum: Serial Communication between PIC16F84A's
PLC or DDC Wi-fi Communication
05/09/2007 12:56 AM
In case of PLC or DDC wi-fi communication in case of network failure what effect will happen on PLC or DDC
Re: wi-fi communication
05/09/2007 5:16 AM
This is dependent on whether your net work is running in real time and looking after a critical process. If if is just data logging and some gaps can be allowed for then ok not so much of a problem. Try to make you local control systems as autonomous as is possible, have alarms for any condition where the situation requires it. Don't get to rely on only one system for any safety related issues. Think what can go wrong then use a flow chart to see where to put your money into the most important things. Think safe be safe.
Good Answers: 53
Re: PLC or DDC Wi-fi Communication
05/10/2007 7:06 PM
The PLC or DDC will continue to operate normally, but without network communication.
Register to Reply 2 comments
