Previous in Forum: Check In or Lose Your Internet Access?   Next in Forum: Video Processing
11 comments
Drag-and-Drop to a CD
04/23/2012 10:50 AM
Even a computer professional didn't know for sure! Can photo files be moved to a CD by drag-and-drop and leave the CD open for future additions? I would like to do this so that all of one subject is on each CD for easier searching in the future.
Lehman57
Re: Drag-and-Drop to a CD
04/23/2012 10:55 AM
I believe you can, just so long as your CD is rewriteable (CDRW). Otherwise, it will become read only and will be stuck on there.
The first law of thermodynamics is you do NOT talk about thermodynamics.
04/23/2012 11:24 AM
You can save them to file to be written to cd, until you reach the space available on your cd, then write the cd....If you want to store them off the computer and add files now and then, it would be best to use a USB flash drive...You can drag and drop files in anything...
http://bestnetguru.com/winxp/burning_cd.html
Good Answers: 104
04/23/2012 12:07 PM
Yes, sort of. Some programs support what's called packet writing (originally incremental packet writing) that allow drag-and-drop and leave the disk open. However, there seem to be compatibility problems between programs and even versions of the same program, such that the potential of losing access to the data is high . You can Google 'packet writing' for more detail.
Here are 3 possibilities:
1. CDR's are cheap. Write to a CDR using the regular record-at-once method. Then when you have more photos, copy the old files off your CD, add the new files, and burn a new CD. Throw the old one away or keep it as back-up, but make sure you keep up with the latest one.
2. As Mizuti mentioned, you could do basically the same as in 1., but erase the CDRW and re-use it instead of throwing it away. I don't know how many times a CDRW can be erased and reliably record again.
3. Use an external hard drive. This would allow files to be added/removed/re-arranged at will and can be connected to any PC with a USB port. This would be the most convenient if you are adding photo files often.
04/23/2012 9:15 PM
Probably a hardware specialist...
Sure you can drag and drop files to a CD. Most CD burning programs do support this function. The same program also let you do the choice of closing the CD or leave it open after burning. In this case any new addition to the CD would make it a multi Session CD. The problematic comes with the reading device and whether or not this can handle Multi Session. DVD player might struggle when trying to display on a TV.
The other thing would be trial and error. With CD's cheap as ... anything why don't you try and let us know how it went. No need for experts when you have the toys to play with in front of you.
Good Answers: 94
04/24/2012 4:23 AM
I agree with this but would just add that 'open' CDs can have trouble being read by anything other than the machine they were written in. The same can apply to CDRWs.
Good Answers: 213
04/24/2012 2:22 AM
I have been doing this for several years now with no problems.
Oh, I don't use Windows.
Never mind.
04/24/2012 7:06 AM
What then, do you use? Please please tell me.
Good Answers: 213
04/24/2012 10:17 AM
I use Ubuntu Linux (10.04- can't vouch for newer evolutions of the distro) and Brasero. CD's are readable on multiple machines, but require "closing" to be read on Windows machines. Using "RW" disks, it is possible to add/modify files even after the disks have been "closed" (Brasero lets one "re-open" the disk).
You do not need to change your operating system. You can set up a Linux (any flavor- Mint my be a better choice these days than Ubuntu) as a dual boot system (unless you are using Windows 7, from what I understand), run from a LiveCD (in which case you lose the ability to write to another CD, unless you have multiple drives) or a thumb drive without modifying your current system set up, or run in a Virtual Machine (VirtualBox, VMWare, many others). From your Linux instance, you can access all of the files on your Windows sectors.
CAUTION: once you discover how easy, versatile, stable and maintenance-free Linux actually is, you may find yourself abandoning Windows all together.
PS- The issue, as I understand it with Windows 7 is that it allows other software to write security information to the boot sector, which can reek havoc with a dual-boot set up. I have not experienced this personally, and this information has been gleaned from various sources like user's groups, blogs and technical articles I have read over the years. If you want to use Linux with Windows 7, the best solution seems to be adding another hard drive to your system- easy enough even with a laptop using an external hard drive.
Good Answers: 26
04/24/2012 10:31 PM
I tried to get my new laptop with Windows 7 to dual boot, but Windows 7 would not play nice. I slicked the drive and set up an encrypted LVM with 64 bit Debian Squeeze. I haven't has any problems out of Windows 7 since!
04/24/2012 11:45 PM
Thank you, Thank you.
Jim
04/24/2012 11:23 AM
Using the built-in burning capabilities of Windows (XP and up) you can do this. Windows does need to know that burning is allowed for the drive/burner you are using, but if you haven't touched any of Windows, default settings, it most likely is. The key part you are desiring, which is to have a multi-session disc, is most likely what Windows is doing. To confirm it, just do a test and drag a few files to the drive in My Computer. This will also tell you if drag and drop can happen with a non-rewritable disc. If it does, then try to read the files and if the burn was OK then repeat the process. If it works again, then the disc was burned as a multi-session disc.
Register to Reply 11 comments
Barchetta (1); bigg (1); cwarner7_11 (2); IdeaSmith (1); JIMRAT (2); Mizuti (1); Nigh (1); Passerby (1); SolarEagle (1)
