Previous in Forum: Dimmer Circuit Configuration   Next in Forum: Microwave Oven Carousel Drive Motor Reversing
Transmission Loss
05/07/2012 9:10 AM
How to calculate transmission losses for a HT transformer / LT transformer which is always loaded above 80%
Pathfinder Tags: transmission loss
Re: Transmission loss
05/07/2012 9:14 AM
05/07/2012 9:44 AM
i have 2 no 20 MVA transformer whose KWH consumption is nearly 201600 units per day from this it goes to ATS (auto transfer switch) then to 6 no 3150 KAV transformer for these transformer how to calculate transmission losses
05/07/2012 10:14 AM
I won't do your homework, or your job.
Google: "how to calculate transmission losses".
05/08/2012 6:51 AM
then y u r here?
to reply for all mails in the stupid way
if u don't know accept ur fault
05/08/2012 9:00 AM
I only reply to certain "mails" in a stupid way.
Usually just to those who are sent by someone too lazy to do any research for themselves, such as this one.
India - Member - New Member
Good Answers: 164
05/07/2012 10:38 AM
Please don't be offended, but if you are qualified and experienced enough to be responsible for 2x20MVA trafos and associated equipment, you wouldn't be really calling the energy as 201600 units. You would call it 201.6 kWHR. And what is 3150 KAV? Is it kVA? If so, wouldn't you call it 3.15MVA? And your title "Transmission loss" should really be referring to the loss in long transmission lines?
05/07/2012 2:18 PM
transmission loss = 1000/total consumption *ratio of current flows through the ATS
Luck comes and goes. Skill is forever. Intelligence either is, or it ain't.
Register to Reply 7 comments
87.saranhp (2); kvsridhar (1); lyn (3); surenhar (1)
