Previous in Forum: Different Types of Plants   Next in Forum: Sizing of Piping
Current to Pressure Converter For Use With DM Water
05/11/2012 7:53 AM
We are working on a turbine with hydraulic governor using DM Water as the fluid. To convert it to electronic governing system, we are looking for a I-H converter suitable for DM water apllication
Inlet signal 4-20 mA
Supply pressure - 14 bar
Outlet pressure 0-10 bar linear
Flow rate aound 40 lpm
Please advise if these are available and if so, the contact dtails of the supplier
vsraghavan@powerconceptsindia.com
Pathfinder Tags: DM Water I-H Converter
Re: Current to Pressure Converter For Use With DM Water
05/11/2012 8:20 AM
Google 'control valve'
Toto, I've a feeling we're not in Kansas anymore
05/11/2012 9:20 AM
Speed Control System for Turbines
Aren't you supposed to know this stuff anready?
Good Answers: 104
05/11/2012 9:31 AM
Please clarify your system description. When you say hydraulic, are you referring to water or hydraulic oil - 14 bar would be a low hydraulic system pressure. Is the 40 lpm the DM water flow or the hydraulic fluid flow? If hydraulic fluid, this must be a large governor.
Are you looking for a pilot-type valve for a closed-end hydraulic loop? If so, I know they are made, I had one delivered on a homogenizer but it was a 2000 psi system and I doubt it would flow 40 lpm at 10 bar. Don't remember the manufacturer, check the hydraulic controls makers.
05/11/2012 12:49 PM
Judging by the OP's e-mail address, I'd say he's just having some fun with us.
Good Answers: 104
05/11/2012 2:55 PM
Yeah, based on his previous post, too. I've started checking 'references' before I bother replying most of the time, but this one slipped by.
bigg (2); lyn (2); MagicWand (1)
