Previous in Forum: Audio Equipment   Next in Forum: Smart Meters
11 KV Motor DOL Starter
05/15/2012 2:40 PM
To start 11KV Induction Motor , DOL Vacuum Switch gear or Vacuum DOL Contactor may be used. But which is preferred? and Why?
Re: 11 KV Motor DOL Starter
05/15/2012 7:23 PM
It depends on the application and making and breaking capacity of the switching elements, but I would think that using a separate contactor would have far more advantages for example remote motor control starting and stopping, switching life, etc over switchgear (which is generally used for isolation and possibly protection if fitted with fault interrupters, etc rather than repeatedly load breaking a high current load).
Sure you could use switchgear, but automating switchgear for remote operation is expensive (if it can be done at all - it depends on the model and brand of switchgear), and it is not as flexible as using a separate contactor.
Reply to Forum Thread
