Previous in Forum: Causality is Dead?..Long Live Quantum Reality? "ffutS sneppaH"?   Next in Forum: Pictures For Collets That I Want to Identify
13 comments
Identifying Lathe Collets
05/17/2012 8:06 PM
I have some collets for an old lathe that I would like to identify so I can purchase more. The collets are approx 2.04" long. The thread is 5/16" with 32 TPI. and the shaft is .365". The collets have a through hole. Any help would be appreciated.
Good Answers: 38
Re: Want to identify collet
05/17/2012 8:32 PM
could you post a picture of them?
like for example:
Re: Identifying Lathe Collets
05/17/2012 9:31 PM
metal ? what this ?
Register to Reply Off Topic (Score 9)
05/17/2012 10:26 PM
05/17/2012 11:15 PM
Maybe something like a Unimat lathe collet?
Good Answers: 59
05/18/2012 10:58 PM
The Morse taper in the inserts come in only 8 different variety, of which I am only familiar with 2 on the chuck side. Please check Wikipedia, and start from there.
05/19/2012 9:09 AM
Google search for Hardinge Work Holding Tooling. You'll find a virtual cornucopia of various collets and tooling for lathes and mills.
05/19/2012 10:26 AM
These collets are probably not for lathes. They look like Bridgeport mill collets and their description also fits. They come in sets and are available from machine shop suppliers. Call one of your local machinists and ask where to get them. By the way, lathes have chucks.
A hand without an arm is a useless tool
05/19/2012 3:06 PM
From your description these collets may be from a jewlers/watchmackers lathe or a small instrument lathe such as a boley.I have seen more than 4 different collet dimensions used on watchmakers lathes, the Boley size being the most common. Does your lathe have any markings on it that could give us a clue?
Good luck,
Doug
05/19/2012 6:00 PM
These are R8 collets primarily used on milling machines.
always find time to do it right the first time or.............................
05/20/2012 4:38 PM
You are absolutely correct. If they were lathe collets they would not be threaded on the pull end. I have used many of them in the machine shop over the years. They are made to hold mills tightly in the milling machine.
05/20/2012 7:04 PM
R-8 (Bridgeport collets and tool holders) are threaded 1/2-13 and an example of Bridgeport collets are shown in #1. However, these aren't the collets in question. The collets in question have a 5/16-32 thread.
05/21/2012 12:07 PM
Maybe they are not Bridgeport but they are not meant for lathes.
05/21/2012 12:12 PM
Here is a link that has a picture of a typical lathe collett.
http://www.roviproducts.com/Hardingecolletpricesheet.htm
_________________________________________________________
A hand without an arm is a useless tool.
Register to Reply 13 comments
Byron Jay (4); Doug (1); Epke (1); evaluator (2); leveles (1); lyn (1); SolarEagle (1); strongcrusher (1); TRICKYDIC (1)
