I'm looking for ideas on how to produce a black metal hinge which is strong enough to sustain the typical stress of daily eyewear use, but also ductile enough to be bent slightly into place.
The inspiration comes from the old medieval hammered iron door hinges, and I'd like to preserve that look if possible.
In the drawing below there are two screw holes in the temple hinge (longer piece pointing to 11 o'clock, only the end screw assembly visible) and one for the front hinge. This will press both sides together, securing it via a threaded cylinder through the frame and into itself, the screws going from the outside toward the cylinders. The frame and temple arms will be pre-cut with the stamp detail impression on both sides to allow a tight fit.
It would be preferable to use a single piece for each the front and the temple hinge, as in the drawing, thereby setting the side with the cylinders in the pre-drilled holes of the frame material, and bending the other side around to line up with the holes.
The screw diameter is 1.25mm for reference.
Also, I am curious which metals would handle all my demands. If iron, should I look at malleable (which I have read is good for small objects such as this), wrought, cast or ductile? I may be able to do a black patina in bronze, which could mold easier. This brings me to fabrication: should I machine or mold? Investment casting has been recommended over sand casting, though no investment casters want to work on a piece of such small size. I image whether I go CNC or mold I'd have to tap the female thread anyway, yes?
Thanks!
