Previous in Forum: Opening In Flat Head As Per ASME Section VIII Division 2   Next in Forum: Hot Tap Question
17 comments
Explain Fluid Dynamics Behavior for the Fig. Below
05/30/2012 10:10 AM
when the Flow direction is from right or left to the cylinder, magnus effect applies. but what if the direction of Flow is from the front of cylinder as shown in the figure ? and how the Drag and other possible force employs ?
i've been searching on internet but the level of confusion is increasing and many of them were unexplanatory. thanks in advance..
Re: Explain Fluid Dynamics Behavior for the Fig. Below
05/30/2012 2:26 PM
In the case shown the rod would try to rise.
It would also twist, unless it was traveling along the equator, (Of course, we all know what the orientation of the rod to equator wolud be, right) then it would fly straight.
A ball is not subject to twisting owing to its perfect mass distribution around its center.
.................................................................................I forgot what the question was...............................
05/31/2012 10:26 AM
Just ignore this, I mis-read the question.
Bullet trajectory is a different animal. For one thing, very seldom will a bullet have the same diameter along its entire length.
05/31/2012 1:17 PM
probably not..
05/30/2012 4:26 PM
What you are describing is what a spinning rifle-bullet experiences, i.e. no Magnus effect*, because all areas on the cylinder's curved side experience the same friction and air (fluid) speed, while the Magnus effect is a result of a difference in those.
It would be pretty bad if you aimed straight and the bullet veered off due to old Magnus...
*SIDE WINDS (excluded for this discussion) do affect spinning projectiles with a Magnus force, but the spin also provides gyroscopic stability.
05/31/2012 1:56 AM
Exactly !! the question was raised after seeing a spinning rifle-bullet.
sir can you please guide me where would i find theoretical analysis on spinning rifle-bullet ? i want to learn difference between spinning bullet and steady bullet and get theoretical knowledge on there efficiency.
i've referred few fluid mechanics books but i didn't find the case where fluid flow direction is as shown in the attached figure (or reference to spinning bullet)
as i was curious about it, i just prepared a model and done analysis on ANSYS 13 Fluent software where i found out that, spinning model shown 3-6% less Cd at different RPM than a steady model.
please tell me very can i get theory behind the Dynamics of spinning rifle bullet sir.
thank you.
Good Answers: 109
05/31/2012 8:54 AM
So is your question directed only towards the bullet?
This would probably be a case of the Magnus effect.
At least thats what they say here.
http://en.wikipedia.org/wiki/Magnus_effect
There will be much more in the internet. Which searches did you try already?
05/31/2012 4:22 PM
Need to read that wikipedia article carefully; it says the Magnus effect develops only from cross-winds or yaw, where the air flow is not exactly along the axis of the bullet, and the portion of air flow that is perpendicular to the bullet axis will cause a small Magus effect.
The question above specified the flow being along the axis of the cylinder... so no Magnus effect for this case.
06/01/2012 2:03 AM
thanks for responding sir..
this is the point where i was struck sir..
link says that we need to consider magnus effect whn a bullet is fired at an angle..
should we consider it as "negligible magnus effect" or "no Magnus effect"
06/01/2012 11:36 AM
If the flow is exactly as in your original question, i.e. 100% along the cylinder axis, then there should be no Magnus effect since the cylinder experiences the same fluid interaction everywhere around its spinning envelope.
When there is an angle between the flow and the axis of spin, you can break the flow vector into parallel and perpendicular components, relative to the cylinder axis, and the perpendicular component of flow will create the Magnus effect, per available equations.
May I ask about your age and country of residence?
06/01/2012 11:47 AM
that was pretty clear.. thank you sir..
by the way i'm kanney, 23 years old from India.
05/31/2012 10:04 AM
This paper on drag crisis may shed some light on your question.
05/31/2012 11:31 AM
Just googling gyroscopic stability in bullets ?:http://www.nennstiel-ruprecht.de/bullfly/gyrocond.htm
05/31/2012 11:35 AM
Here is a link to a site called "How Bullets Fly"
It looks very comprehensive....
Ferquiza beat me to it!
05/31/2012 1:10 PM
thank you.. that was very helpful.
now i wanna know how would these equations change when water is the medium instead of air???
thanks in advance :)
05/31/2012 1:41 PM
We've already gone over this once:
Hydrodynamics
It's sounding too much like the children's game 20 questions.
06/01/2012 1:40 AM
yes.. we've already gone through something related to this..
for that you've replied with "Your instructor should be able to answer this question for you, in the proper context for your level of knowledge."
you have never helped me out in the subject but pulling down my interest levels on learn something... please stay off if u've nothing say regarding my doubts.
06/01/2012 9:56 AM
Here's some advice. Learn :How to Search the Internet.
Then maybe you can get the basics first. As you can see, there are many here willing to search the net and list the sites for you.
Good luck.
Register to Reply 17 comments
Calnet42 (1); Doorman (1); ferquiza (1); IdeaSmith (1); lyn (4); miklosh (3); skoo (6)
