We manufacture a product which has a interface between SS and Mild steel for purely commercial reasons. Would like to know the possibility of galvanic corrosion in an controlled environment. By controlled environment I mean the equipment is located in a closed shed well protected from sun and rain. In side the equipment, wood pieces are burnt under controlled condition to extract the gas which is burnt in a engine to produce mechanical energy.The temperature inside the equipment is around 12000 C.
Are there any galvanic isolators withstanding such high temperatures?
